AFJuvat's Avatar
Guess the problem part 2
The second in the series of "test your troubleshooting skills"
Vehicle: 86 944
Mileage: 126000 miles
Clutch (spring centered), Pressure plate, TO bearing, master and slave replaced 15000 miles ago. Flywheel meets specification and was refaced at the time of clutch replacement
Car runs normally. Customer complains of clutch slipping at high RPM or at high torque. Smell of burnt clutch material.
No other noises, but customer states that the car just doesn't have the "oompf" it used to.
No further information
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 02-18-2003, 06:52 AM
944S Boyeee's Avatar
Send a message via ICQ to 944S Boyeee
Would a spring centered clutch make a burning smell???
Could the torque tube be loose??
944S Boyeee
1989 928S4 Canadian Edition
75,000 klms
Old 02-18-2003, 07:16 AM
Bob's944's Avatar
Send a message via AIM to Bob's944
Lightbulb
Was just up till 2 am last night helping a friend with a ford probe gt replace his clutch. His symptoms were similar at first, but became worse. His Throw Out bearing was failing first, losing power at high RPM's and when he punched it off the line. When you would engage the clutch at low RPM's without giving it good revs, the engine would try to stall out. The next thing to start occuring was the sound of parts falling off, he was driving the car alil over a week before it was repaired. After getting the clutch out, the surface of the clutch material was ok, the TO bearing was GONE and several 'fingers on the pressure plate broke away. New clutch is in, along with a new flywheel... he's very happy.
Old 02-18-2003, 07:18 AM
daveimme's Avatar
Send a message via Yahoo to daveimme
Yeah....I bet he was happy (for once) he didn't have a 944, right?
I'm curious here, too.....my limited knowledge points to the clutch springs being too weak?? (just don't laugh, ok?)
83 944 N/A 5 sp. (mine)
90 Acura Integra auto (sons)
2000 Honda Odyssey EX auto (wife)
83 Suzuki LT 125 (4 wheeler) (wife)
92 Honda XR 80 (son)
97 Honda CR 125R (son)
98 Honda CR250R (MINE)
2000 Kawasaki KX 65 (son)
2003 Honda XR 50 (Son and daughter)
Old 02-18-2003, 07:23 AM
AFJuvat's Avatar
Torque tube: No noise or vibration indicated
TO bearing: on the right track, but they usually make noise or vibrate when they start to fail.
Clutch Springs: Fine
Car is daily driver, not tracked. Owner does know how to drive a manual transmission vehicle properly - driving habits are not indicative of abuse.
AFJuvat
Old 02-18-2003, 07:35 AM
todwic's Avatar
Send a message via AIM to todwic Send a message via Yahoo to todwic
accidently replaced the 944 clutch disc with a 924 disc? hehe
*Disclaimer: The person above is actually dumber than he appears.
my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements
'84 944 auto/ps/ac/cc
'86 951
Providing ignorance one post at a time.
Old 02-18-2003, 09:25 AM
SoCal Driver's Avatar
Broken clutch fork not letting the TOB move "back" properly.
Or a cat got caught in the bell housing.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 02-18-2003, 10:59 AM
88_944's Avatar
Small leak on the Slave Cylinder that's shooting oil on the disc.
My Black 944
My Gaming Forums. Xbox360gen.com
Old 02-18-2003, 11:49 AM
PorscheG96's Avatar
Send a message via AIM to PorscheG96
I think you're on the right track.
My guess is leaking rear main. Moral: While you're in there, might as well do this...and this...oh, that too.
Old 02-18-2003, 12:02 PM
ae1969's Avatar
Send a message via ICQ to ae1969
rear main seal
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 02-18-2003, 01:28 PM
AFJuvat's Avatar
So many that are close, and yet so far away.
Hint: As I said before, Nothing is leaking
AFJuvat
Old 02-18-2003, 01:34 PM
PorscheG96's Avatar
Okay...if the clutch is SLIPPING then there's not sufficient friction on the clutch disc. Since you say there's nothing leaking, and the clutch was replaced recently, then something is adjusted incorrectly with the clutch fork/pressure plate which is allowing the disc to slip.
Old 02-18-2003, 02:00 PM
ilikemy944's Avatar
Send a message via AIM to ilikemy944
The pedal is not adjusted properly - too tight, not allowing clutch to release completely.
Brad Tompkins
Current: '86 951 Sunroof Delete - '89 951 - '83 944 Spec - '08 Cayenne Turbo
Past: '88 924S Track - '86 944 16v - '87 951 - '87 951 - '88 951S - '08 Cayman S - '87 944 Track - '93 968
Old 02-18-2003, 02:07 PM
OK it's not a cat.
A possum?
Old 02-18-2003, 02:08 PM
ae1969's Avatar
they put the rings/clips on the throw out bearing wrong or came loose.....
Old 02-18-2003, 03:25 PM
AFJuvat's Avatar
BINGO
5 minute repair, 12mm wrench and a 9mm wrench, fixed.
AFJuvat
PorscheG96's Avatar
Where are the clutch pedal adjustments made at [just for future reference and my curiousity]? Thanks.
Old 02-18-2003, 03:43 PM
Who replaced the clutch and other items?
Old 02-18-2003, 03:47 PM
Roger Hall's Avatar
Guess thats why I am not a mechanic. I would have thought TO berring was not disengaging. It would have been partial right but by that time I have allready pulled the tranny.
Roger Hall
81 924 N/A
Some people are like Slinkies. Not really good for anything, but you
still can't help but smile when you see one tumble down the stairs.
Old 02-18-2003, 04:24 PM
AFJuvat's Avatar
Actually, I replaced the clutch.
Owner adjusted the cylinder for a "stiffer" pedal.
You make the adjustments at the clutch master cylinder - you screw the rod further in the pedal to loosen the pedal, and unscrew it to "tighten: it up.
Should have a couple of MM free play be design.
AFJuvat
Old 02-18-2003, 05:00 PM
