carolinus's Avatar
Optibelt tool...
I am looking for opinions on the optibelt tool, and possible sources for it. What do you guys think? Is it a viable replacement for P9201?
I am blessed/cursed with these cars:
BMW 318iS 1991
BMW 325iS 1988
Volvo 740 Turbo Wagon 1992
Quote of the week:
"This chemical is known to cause Birth Defects in California."
Poor Californians, they are always getting the short end of it, and now this?
Old 02-25-2003, 06:23 AM
The Optibelt Tool costs ~$50 and the P9201 costs $364 (see http://www.weissach.net/P9201.html).
Personally, I'd pay the $314 delta for the genuine tool.
Karl.
Previously: 1991 944 S2
Currently: Something from München...
Old 02-25-2003, 07:50 AM
AFJuvat's Avatar
Can you use it to tension the belts - Yes
Is it reliable or accurate consistantly? - No
Here is where the problem comes in - the 9201 gauge is expressed in scale units (example, 2.7 scale units for the balance shaft belt)
2.7 scale units does not relate to anything (a given deflection value, xftlbs etc.)
In order to have a snowballs chance to tension it accourately, you would have to tension the belts with the proper tool, and then take measurements from the optibelt tool, repeatedly, to ensure accurate measurements.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 02-25-2003, 09:08 AM
944pete's Avatar
I bought the Kriket tool (looks identical to the Optibelt) at NAPA for $9.80 plus tax. I'm going to try it out and compare values to the 9201 if the weather ever warms up.
Where is global warming when you need it?
Pete
1989 944S2-Dove Blue Metallic
1985.5 944-Alpine White--sold
My P-car Online Profile
Old 02-25-2003, 10:03 AM
This site gives tensioning values in lbs for use with the Optibelt tool:
http://www.blaszakprecision.com/Belts.html
Please let us know how the tool performs.
Gene
Gene
____________
'86 944 NA
'88 Citroën 2CV
Old 02-25-2003, 10:21 AM
carolinus's Avatar
I will probably have an opportunity to compare P9201 output with this tool. Apparantly this tool was designed by Optibelt to measure the tension on the replacement belt needed here. As such, it even has the markings on it for the recommended belt tensions from the factory. Ach so, we shall see.
BMW 318iS 1991
BMW 325iS 1988
Quote of the week:
Old 02-25-2003, 07:49 PM
I've used the Krikit (same thing I think) for 6 years now. No problems. I leave the balance shaft belt looser than what is recommended. If I don't, it makes a whirring sound. I set the cam belt to what is recommended on the index. This gets done yearly.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 02-26-2003, 03:53 AM
carolinus's Avatar
Krikit is very similar, in my understanding. And if you do a belt a year, I suppose you should be fine.
BMW 318iS 1991
BMW 325iS 1988
Quote of the week:
Old 02-26-2003, 05:51 AM
