A/C Tensioner bolt size
I lost the a/c tensioner bolt on my early 944. Does anyone know the size of a replacement bolt? Looking to get something asap. Would a hardware store have anything that would work? Thanks in advance, picture attached
http://i822.photobucket.com/albums/zz147/rexlt/944%20tensioner%20bolt_zpseu2ubolv.jpg
Old 04-22-2018, 12:12 PM
9FF 9FF is offline
9FF's Avatar
You can look it up yourself in the Porsche parts catalog (PET).
It’s a hex head bolt M10x1.25x30 (item 48) and you’ll need M10 washers and locknut to go with it. If your local hardware store carries machine-grade metric bolts like mine does then they should have them.
Mike A
9TECHNIK | TRANSAXLE ÄRA
1986 944 (Street); 1986 944 (Track); 1986 951; 1989 951 (3.0L 8V); 2000 996 Cab.
Old 04-22-2018, 12:45 PM
kuehl's Avatar
Rex,
on the compressor side try a M10 x 30 mm.
the other end would be a M8 x 32 mm
Griff
Kuehl
1987 911 cab, modified
https://griffiths.com/
Old 04-22-2018, 05:08 PM
