S2 oil change
I know there are Lots of oil threads out there, so I don't want to start another.....but I do want to know if anyone adds a ZDDP additive to std oil? If so, what kind? Currently have Brad Penn 20W-50 and a Mahle filter in there.
Any other oil brand recommendations? Regarding the method, I was planning on not jacking the car up as I can get to the drain plug easily. I will punch the hole in the filter before I remove, but will I need to remove the forward pan on the bottom to clean up? Will use rags around the base to avoid spillage. I having been changing all my cars for years, however, the 944 seems to be a bit of a challenge. Last edited by jep32; 09-01-2011 at 06:36 PM.. Reason: Spelling |
unindicted co-conspirator
i want to know how you can change the oil without lifting up the car, unless you are a flounder, how do you fit under there?
'03 996 - sport exhaust, sport seats, M030 sport suspension, stability control, IMS Solution ‘86 928S3 - barn find project car |
Garage Helper
A suction tube down the oil dipstick tube - have done it that way several times when in a hurry...Does not let you check out things under the car though.
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now). ![]() UAV-M1 (Urban Assault Vehicle - Model 1) Bless the lowered, and pass the nitromethane. Pedal to the metal till you see the gates of hell then brake NLA - No longer available is a four letter word |
Just need to get to the drain plug, I can get to from the side
Proprietoristicly Refined
If your S2 still has the engine pan, you will need to lift the front of the car.
I have tried many times to save time by packing the bottom of the oil filter with lots of rags to catch the oil only to find that when I pull the rags out, some of the oil still got on the pan. Brad Penn is good oil. No additional additives required. I change my oil/filter at about 3500 miles. Mahle filter is the best for the oil antidrain back valve. High mileage cars over 140K, even with regular oil changes should have the rod bearings changed. This is required especially if the oil cooler gaskets fail and coolant mixes with the oil -per Porsche. Many threads on spun rod bearings. Repeating what Cocacolakidd said, it is a good time to check other parts under the car. Just good maintenance. GL John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo) Last edited by John_AZ; 09-03-2011 at 03:35 PM.. |
Thanks for the feedback folks. I'll put it on ramps and remove the pan, good points about checking things out. Just wanted to avoid the low front against the ramps and rear batwing interferance with ground........Going with Mahle/Brad Penn, seems to be just right for this car.
Have anyone had luck with punching the hole in the back of the filter to create air flow, or let it drain overnight to avoid spillage downt the side of the engine, or is this just inevitable? Only have around 2k since last oil change, but it was a hot summer in the midAtlantic. Car has 47K on it now, I want to keep it in prime running condition. What about tranny fluid change? Whats the frequency and what do you folks use? |
Garage Helper
I have punched a hole in the filter for faster drainage in the past, but have found that to let it sit for a bit, wrap rags around it is a better way to do it. In the past when I punched a hole in the filter I found this breaks up the inside of the filter and allows allot of debris to flow back into the engine.
I want to keep all of the bad stuff out of the motor so I do not punch holes in the filter any more...I finally got tired of the stupid filter mounted up-side down, and all of the spillage. So I placed a remote filter adapter lower in the side of the chassy - so now it comes off without a drop spilled, and from underneath - the way it could have been in the first place. I'm using Valvoline Synthetic 90 in my Transaxle, and change it out every three years - it's easy enough to do and not that expensive.
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Guys, lots of interesting information and nice pics but nothing to address the real question here... do you add ZDDP = NO for a 1989 Pcar... you are better off just keeping with Mobil 1. Second question... I personally decided to upgrade to the Canton cartridge filter unit when I replaced my motor mount for the second time and completely cleaned the engine compartment from bottom to top. For you Mahle filter folks, I suggest you make a call to your local Napa store and get the form-a-funnel drain tool. It is far better than all the rags and paper towels you can stuff in there.
1989 944 Turbo (100% stock and restored) ![]() 1996 Mustang Cobra - Track Ready via Griggs Racing |
First part I agree. But... The op is using Brad Penn 20-50, no need to change to Mobil 1. John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo) |
Garage Helper
The rear side shields are plastic on the S2's
The problem with getting a Flounder to help out is they always want to many Anchovies, and you have to flood the garage floor with salt water up to about 6".
Ok, just got the rhino ramps....hope it clears. Still very confused as to what oil to use....so going w/Penn 20w-50
PS: a shot gun shell, a spear and a bunch of clubbing is what I find does the trick.
-1986 944 NA |
jep32 -- how much did you pay for rhino ramps??
Rhino ramps are like $40 at AutoZone...Don't get the ones from Harbor Freight there cheap, and I use Valvoline 20w50 Racing VR-1 (conventional, not synthetic)..Has some ZDDP in it, or Castrol 20w50 with a bottle of STP blue oil treatment...
Beer Cigars and a 10mm socket... |
Those are mine.I paid I think is around $60.oo a few years back (but that is up here in Canada) ,down your place should be cheaper.They are fabricated by (Blitz)here are the specs 12,000lbs GVW-3,000pds each-6,000pds per pair.
$50.....decided on M1 15W-50.......just availability, plus it's got about 1,300 ppm zinc from what I read. Have the wrench to loosen, new plug seal.......ready to go!
