Mal81's Avatar
Early 928 K Jet Fuel Line Revisit
Hey Gang,
Not trying to start a flamethrower fest, as it seems to be a sensitive topic to some...
Does anyone have any experience using Aeroquip socketless fuel line? Can this line be used with the Porsche barbed fittings, or should I use Aeroquip fittings? If so which fittings should I buy?
Fittings - Socketless Fittings - Socketless Hose Fitting
Thanks,
1981 928 Euro "Babied and Pampered"
Old 07-03-2018, 09:54 AM
umop apisdn
The Genuine Aeroquip hose is very good quality stuff and I've been using it extensively on project vehicles for a couple of decades, however I'm very careful about where I use it and what for.
there are a few important things to consider:
AQP socketless hoses are in imperial (inch) fractional sizes and the Porsche fittings and hoses are metric (mm) sized with no interchangeable equivalents so don't mix and match hose and fittings as the socketless concept requires very exact sizing matches for the hose to grab and seal properly
Where possible use a correctly sized AN-Metric adapter or fitting, or get creative and there are weld on fittings that can be used to convert OEM line fittings and hard lines to accept sections of AN hose
Its a hose system designed for high frequency maintenance and inspection situations, military/aviation/racing etc., so inspect for leaks and faults regularly, it will probably last longer than normal rubber line but it is definitely not a fit and forget OEM part.
see http://aeroquipperformance.com/file/2781-Hose+Maintenance+and+Inspection+of+Hose+Assemblies .pdf
Their hose is happy with most fuels and fluids but does not like return based fuel systems
A Caution about Fuel Injection
All hose listed in the AQP Performance Products catalog are
suitable for use with leaded and unleaded fuels. However,
caution must be used in fuel injection systems that recirculate
fuel. This causes fuel to oxidize which can attack the hose inner
tube. To increase service life, keep the time of exposure to
the oxidized fuel to a minimum. Drain hose line or flush with
original fuel or other suitable material.
have a read through the documents at Technical Specs
1981 928S 4.7 ROW with KE3-Jetronic and Franken8 (AEM Inifinty) "Be the man your dog thinks you are."
Yes! mechanical/hydraulic constant flow injection can be managed by a modern EMS
www.FrankenCIS.com
Old 07-05-2018, 01:04 AM
Mal81's Avatar
Thanks for the help, Steve.
It looks like I will be looking for some of the few remaining OEM spares.
Old 07-05-2018, 10:56 AM
umop apisdn
the genuine components are listed here
Catalogue/Tooling
primarily in part 3
www.FrankenCIS.com
Old 07-06-2018, 02:38 AM
BoxsterGT's Avatar
Porsche Crest
Don't know if I can help but I have had pretty good luck with re-making CIS Lines for the 911 & 924 and some VW products.
E mail me with photos and I will take a look.
Len dot Cummings at verizon dot net
Old 07-10-2018, 08:21 AM
