Center console removal
I believe that the removal of this console should be fairly easy but I am hung up trying to get the temperature/fan component free from the console. What is the trick?
Thank you! Tim |
hey tim - it's been a while but if i recall ..once you remove the radio and trim from around it the hvac head unit is held in by screws - maybe someone who's done this recently would be able to send pics
Thanks, I figured out. It easy once you remove the trim.
| All times are GMT -8. The time now is 06:20 AM. |
