porsher
aston@ultrasw.c's Avatar
Fs abs control module
PORSCHE 944, 968 928 ABS CONTROL MODULE 92861811905
OEM part, removed from 1988 S4
$140 shipped, lower 48
Cheers
86 911 Race Car, with a few 993 bits in the boiler room
79 928 Race Car
88 928 Becoming a Race Car
Old 07-11-2021, 01:36 PM
porsher
sold
79 928 Race Car
Old 02-17-2025, 03:58 PM
Quick question since you have deleted ABS! Did you just strip the original harness? Everything work ok without it? I'm building a track car and want to delete mine. Thx!
Old 06-03-2025, 12:23 PM
How did you do the MC and reroute the hard lines? Thanks
Old 06-03-2025, 12:24 PM
porsher
Harness is gone, so are all the original lines, I even welded a plate over the hole!
I did buy a brand new master cyl, that was kinda spendy
New lines to the fronts with a pressure sensor.
I seem to remember removing a pressure limiting valve for the rears but I did install a manual adjustable control valve.
I also sealed up the float port in the reservoir, I think it was leaking.
No issues at all.
79 928 Race Car
Old 06-03-2025, 02:09 PM
Wow thanks for the reply! I've been intimidated to start ripping it out. Just got the motor out and the interior stripped. Now on to the wiring which I want to strip out unnecessary stuff. Was wondering if it could be done. I see the additional Wilwood reservoir you used because of space restriction. Again thanks for this info as it's invaluable to me and doesn't exist anywhere else on the internet. Already converted the rack to manual with the help of The Machine Shop in Colorado Springs. This will further help me build a bulletproof track 928
Old 06-03-2025, 03:13 PM
porsher
Actually, the Wilwood is for the clutch.
Here's the beast
79 928 Race Car
Old 06-04-2025, 08:27 PM
