Ebs Ebs is offline
928 s2
I am considering the purchase of a 1984 Porsche 928 s2. I am trying to research the car for specs on the web, but the info seems very limited.
Does anyone own one of these cars or have details regarding it. I understand that this particular model was only sold in Europe.
All replies are appreciated.
1986 951 Euro spec model
Anthracite on black
105,000 km
K&N, Lindsey Boost Enhancer, chipped, oversize fuel regulator
968 Club Sport anti sway bars
Adjustable Koni Yellows
Fuchs alloy : 9 inch rear, 7 inch front
2.5 inch stainless steel exhaust
1984 928 S2 (Jap spec)
1977 Mazda 323 - hard core tuned
Old 02-28-2004, 07:00 AM
cuda876's Avatar
Wink
what kinda specs are you wanting to know......because i know quite a bite about these cars and all posches and mustangs.......
Old 03-01-2004, 12:16 PM
cuda876's Avatar
for some prformance specs it can average about 20mpg and can go 1/4 mile in under 15 sec. and 0-60 in about 6.5!!!!!
Old 03-01-2004, 12:36 PM
Iggy's Avatar
The euro '84 928 is a pretty impressive beast. It had 310hp, nearly 80 more than what was available for US models (234). Unless it was federalized when brought into the US, it'll have better headlights (adjustable from inside the car), no catalytic converters, and some cosmetic changes including an extra tailight next to the rear bumper pads.
Maintenance may be tricker with the euro model since it employs a different fuel injection system. Parts will be rarer in the US.
Old 03-02-2004, 06:32 AM
Ebs Ebs is offline
Thanks for your replies.
The car is ex-Japan, but I believe it to be a Euro spec model. However it says to run it on unleaded, which I do not believe to be a European requirement in 1984. Do you know if Japan had catalytic converters in 1984 and used unleaded fuel? If it had emissions I fear that it will not develop 310 horsepower and not be a full euro spec car from a performance perspective, what do you think?
Anyone see a top speed road test of an s2?
Thanks for any replies.
Anthracite on black
105,000 km
Old 03-02-2004, 06:43 AM
jpugh1's Avatar
Send a message via AIM to jpugh1
specs and more
definatly check out > http://www.928gt.com/
Old 03-04-2004, 04:49 AM
jpugh1's Avatar
specs link
you will find the "928SP Specs and Technical Info section" link written in blue about half way down the page , just under the side view of the black 928 from this page ~> http://www.928gt.com/
Old 03-04-2004, 04:53 AM
s928s's Avatar
if it came into the us in the 80's or later for that fact . Converters were part of the fed conversion. An easier way is to check the vin, should start off wpo"zzz". from my reading, most of the power is from the lengthend intake runners and pistons. there is definatly a power difference. I had a US 82 928s stick, switched to a Euro 928s auto, added "martin Schneider" headers, 2 chamber muffler and 3 inch pipe. boost the fuel flow and mixture, k&n, 17in anteras...now will do 325hp on the dyno !!! and sounds like a dream.. Have fun.
autowerks9
PCA SINCE 1991, REISENTOTER
1982 EURO 928S 320HP MEDIORMETALIC/BURG.
1987 944S- GT3 BODY CONVErSION RED/BLACK( sold )
2003 MERCEDES E500 Sport "Einfarbig"
Old 03-04-2004, 12:08 PM
Ebs Ebs is offline
It has the wpo zzz vin in the engibe bay. But the engine is 28.20, whereas from my reading the 28.22 is the 310 horsepower euro version (with auto transmission). So what do I have? A normal 928s or a euro 928s2?
What do you all think?
Anthracite on black
105,000 km
Old 03-08-2004, 07:13 AM
s928s's Avatar
euro spec 928s...the "zzz" in the vin is the euro spec..28.20 is correct as well, it is a 310 hp version. sould also have side turn signals behind the front wheels, a knob on the inside where the e-brake handle is for the adjustable headlilights, probably disabled..supose disable for fed conversion. the rear fog light. depending on the importer it may not have rear bumper pads also, mine does not, usally they were installed. one other way i have seen is in the cluster, the words are written on the faces in english, but when they light up they are in german. good luck.
autowerks9
Old 03-08-2004, 08:39 AM
Ebs Ebs is offline
Thanks David. I don't mean to reiterate the same things again, but the 28.22 is the hot engine isn't it, not the 28.20. Plus the car has a catalytic coverter, but the high compression engine would not use unleaded fuel would it?
Anthracite on black
105,000 km
Old 03-11-2004, 06:57 AM
s928s's Avatar
I DID A LITTLE MORE RESEARCH FOR YOU IN THE FACTORY SPEC BOOK. AND THIS INFO MAY HELP, YES THE 28.22 IS THE LOWER HP ENGINE VERSION. HERE IS THE INFO ON THE 944 MODELS.
1983/1984
1. M28.21 (310 HP) LH-JETRONIC EUROPE , R.O.W
2. M28.22 (310 HP) LH-JETRONIC EUROPE , R.O.W ( AUTO )
3. M28.19 (242 HP) L-JETRONIC USA & JAPAN
4. M28.20 (242 HP) L-JETRONIC USA & JAPAN ( AUTO )
** R.O.W = REST OF WORLD.
"ZZZ" IN VIN ( 3-6 DIGIT) = EUROPE, JAPAN, R.O.W
"JOA" IN VIN ( 3-6 DIGIT ) = USA & CANADA SPECIFIC
..AN ADDITIONAL NOTE , THE NUMBER 12, PRECEDING THE TRANS CODE NOTES A LIMITED SLIP DIFF.
..I HOPE THIS HELPS, SORRY IF PRIOR INFO SEAMED CONFLICTING. DAVID
autowerks9
Old 03-11-2004, 05:08 PM
s928s's Avatar
Post
MAN AM I AN IDIOT OR WHAT.....28.22 IS THE HIGHER SPEC..28.20 IS THE LOWER HP SPEC..JUST REFER TO THE HP CHART. SORRY!!!:( :(
autowerks9
Old 03-11-2004, 05:13 PM
Ebs Ebs is offline
Thanks for your interest and help David. Much appreciated!
Anthracite on black
105,000 km
Old 03-12-2004, 06:24 AM
