Talk Less, Say More
Location: Moab Utah. Home of wierd red & orange radioactive stuff... And 1 billion tourists.
Dash Lights
I don't drive the car much at night. But last night I made a long haul to Denver and back to Moab in a day.
At night I could hardly see my instruments. Really dim (is this normal on the early models?). I had replaced some of the little bulbs but there must be more... Is there an easy way to replace all and ensure I get all of them? Or is it all convoluted, crawling under the dash etc??
cRaIg CaRr 2000 Dyna FXDX, 2001 Sportster Sport, 2000 R1100S,2007 R1200S,2015 rNineT,2015 Gold Wing, 2023 F850GS,2023 R1250RS, 2017 Triumph T100, 2019 Jeep Rubicon, 2005 Jeep Sport, 2001 Corvette, 1978 Porsche 928. 2001 GMC Sierra 2500HD, 22 pairs of shoes. 24 bottles of beer. |
ckcarr...see topic "Pod lights Out" by Anthony Saul, on this BBS;
i.e., bright/dim adjust. G'luck.
macreel '79 924 (red) '84 928S (copper) |
Talk Less, Say More
The answer is that it is all convoluted.
Take steering wheel off. Take lever module off. Unscrew bolts holding dash unit in place. Carefully pull dash unit toward you and leverage over the sharp steering wheel post without scratching or tearing. Remove instrument cluster. Inspect each light and freshen up contact point with rubbing alcohol. RR as needed. Reverse process.
My mechanic (a Porsche master) changed a bulb just by reaching under the dash on my '84 928.
I don't mean to be rude, but I assume the brightness adjuster is already turned to max.
1986 951 Euro spec model Anthracite on black 105,000 km K&N, Lindsey Boost Enhancer, chipped, oversize fuel regulator 968 Club Sport anti sway bars Adjustable Koni Yellows Fuchs alloy : 9 inch rear, 7 inch front 2.5 inch stainless steel exhaust 1984 928 S2 (Jap spec) 1977 Mazda 323 - hard core tuned |
Talk Less, Say More
There were one or two I might have been able to reach, but not the 10 or so that are hidden in there. I would hope yours is a much more modern setup that the 1978. I also had found advice somewhere about my cleaning the copper contact points with alcohol which I also did.
