need to pull ignition key cylinder
I have done the unthinkable. I cannot find the only set of keys to my '79 928i. It has been a month and they are nowhere. Whats worse is the ignition key cylinder and key were replaced, different key than the door so I have no record of it.
I am assuming the easiest thing to do would be to replace all the lock cylinders. Can anyone tell me how to get the ignition cylinder out, and the liftback door cylinder out. I know the doors, I took them out to paint the car a couple years ago.
Anyone have all new cylinders and keys from a parts car they want to sell?
thanks,
MattM
Old 12-13-2004, 08:59 PM
AFJuvat's Avatar
The lock is held in with a roll pin that has to be drilled out to remove.
You will have to remove the instrument cluster to get at it.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 12-14-2004, 06:22 AM
If all the locks work, remove them all and get a locksmith with 928 experience to change all of them to suit one key. New locks are expensive.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 12-15-2004, 05:53 PM
Old 12-15-2004, 05:59 PM
s928s's Avatar
Donzi..I have a good ignition cylinder with a matched key only if you are interested. $30.00 shipped to you priority. just pm me or email me
((david928s@msn.com))
..need to remove the cluster to access the roll pin, needs to be drilled out.
..the back hatch cylinder in the rear hatch comes out by unbolting it from behind the rear tool panel. i think it is 2 10mm or 8mm, its been a while.
autowerks9
PCA SINCE 1991, REISENTOTER
1982 EURO 928S 320HP MEDIORMETALIC/BURG.
1987 944S- GT3 BODY CONVErSION RED/BLACK( sold )
2003 MERCEDES E500 Sport "Einfarbig"
Old 12-16-2004, 07:15 AM
s928s's Avatar
autowerks9
Old 12-16-2004, 07:29 AM
