Odometer gear fix / replacement
Hi guys
I just found out on my 1984 928S that the reason that my odometer isn't working is because that the brown gear is broken
My mechanic took took apart the cluster so everything is out now
My question is if I should replace the other gears also while everything is apart ( they seem ok and speedometer is working fine )
Also where can I get these gears ?
THANK you very much guys
Old 10-11-2013, 02:09 PM
MPDano's Avatar
Porsche Odometer Speedometer Repair Gears - Rennbay - Porsche 944 ball joints, power steering, brakes, odometer gears & accessories
$27.50
Only that one gear disintegrates itself.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 10-11-2013, 03:45 PM
Old 10-11-2013, 05:02 PM
Petie3rd
Mrmerlin's Avatar
after you get the new gear make sure to inspect it carefully as their can be flash on the teeth,
if there is,
the speedo will jamb and then the job will have to be done again,
this time to file the gear teeth down
Old 10-11-2013, 05:04 PM
Odometer Gears - Porsche - 928 77-95
these guys have been around a long time selling these
Old 10-12-2013, 05:26 AM
Bought the gear from them
Thanks guys
Old 10-12-2013, 09:02 AM
As Stan suggested above it pays to carefully inspect the new gear for flashing...BUT, there is more to be on the look out for when the work is done. 1) look for and remove any protruding flashing on the side of the gear 2) make certain the gear is not too long on the shaft causing the gear to bind up when the "e" clip is installed. 3) make certain the gear is not tight on the shaft which will also bind it up 4) make certain the new gear does not bind on the worm gear on the motor (this is caused by the new gear being slight larger in diameter than the old gear) I have seen all these problems on replacement gears and I have replaced less than a dozen of them. Who ever originally built the clusters for Porsche was not particularly careful about tolerances over time. There are differences from cluster to cluster and there are differences in the replacement gears in sizes, finish, and fit too. There are several people selling the replacement gears and THEY DIFFER from each other. I have gotten the gears from 3 different sources and I don't remember who supplied the ones that fit best....all of them need to be carefully inspected. Otherwise, you will be paying your mechanic to R&I the pod more than once.....these problems are not easily found, on my first drive gear replacement I think I had the pod in and out maybe 4 or 5 times before I got it "right". But, going to school I rode the short bus.....
1956 Intermeccanica 356 Speedster (sold),1957 Intermeccanica 356 Speedster (sold),,1985.5 Porsche 944 (sold),1955 Thunder Ranch 550 Spyder (sold), 1955 Outlaw 356 Speedster (currently in build out), 1984 Porsche 928S (White), 1984 Porsche 928S (Red)
Old 10-12-2013, 12:53 PM
Issue was fixed
Thanks guys
Old 10-20-2013, 08:59 AM
