-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=15)
-   -   Rough Idle (http://forums.pelicanparts.com/showthread.php?t=301342)
gckrek3 08-29-2006 03:50 PM
Rough Idle
cold start up...even when engine is warm, once down to about 900rpms the idle starts to roll between 900 and 950rpms...any suggestions?
Greg Krekeler
Black '85 Porsche 928 S - 5Speed
gckrek3 09-01-2006 03:21 PM
no one? any suggestions will help!
thanks
jstobo 09-01-2006 06:42 PM
If idle stabilizer is okay i'd check for vacuum leaks and dirty injectors. Run some techron through the gas system. I will check my manuals tomorrow and if they have a trouble shooting guide i'll post it tomorrow.
jstobo 09-01-2006 08:11 PM
Hey, i'm back. From the shop manual. For irregular idleing check:
full load contact,engnine temperatue sensor ll, air mass sensor, idle speed control, fuel pressure, intake system leaks, fuel tank venting, injectors. i hope this helps.
gckrek3 09-02-2006 08:38 AM
thank you. i will check these out and let you know how it goes!
thanks
Greg Krekeler
