jim ross's Avatar
help w/instrument bulb replacement-84 928S
I cannot figure out how to replace the main lighting bulb( not warning lights ) on the bottom left side of my instrument panel! Can it be done without removing pod??? any tips would be appreciated! thank you.....jim
Old 01-06-2007, 10:09 AM
s928s's Avatar
Best to remove the pod. It is not too hard to do. You Can access some of the lower bulbs by removing the lower trim covers and parcel shelf.
autowerks9
PCA SINCE 1991, REISENTOTER
1982 EURO 928S 320HP MEDIORMETALIC/BURG.
1987 944S- GT3 BODY CONVErSION RED/BLACK( sold )
2003 MERCEDES E500 Sport "Einfarbig"
Old 01-06-2007, 04:37 PM
Heavy Metal Relocator
rhjames's Avatar
remove the pod. it isn't very hard to do.
928 int'l /tech tips (website) has a nice tutorial on this and other subjects as well.
while you have the instrument panel out, clean all of the wiring connections. be careful with the (plastic) circuit board, it is very fragile. also clean the light bulb connections on the circuit board.
I did mine in (including removal and reinstall) in less than 3.5 hours. I also installed red bulbs while I was at it. much easier on the eyes.
regards---rhjames
Absence of Evidence, is not Evidence of Absence.
Bill Maher 8/4/09--- "I'll show you Obama's birth certificate, when you show me Sarah Palin's high school diploma."
Old 01-08-2007, 06:29 PM
