Network Native
Danglerb's Avatar
Euro fuel map for a US LH on a Euro motor
The motor from my 84 Euro 928S AT is going into my US 83 5 spd, with the brains and wiring from a US 86, using chips with Euro fuel tables and hopefully leaving the US O2 sensor loop functioning.
John Speake can make the chips I think, only thing left is to decide on a flywheel. I can't use the AT flywheel I have, which has me thinking maybe this is a dandy time to try an aluminum flywheel from Carl.
US 83 zinc metallic 5 spd, aka the nice car.
Euro 85 black, 5 spd, the fast rough track car maybe car. SOLD
Euro 84 red, AT, only car in garage in years, my parts car, soon to go last 7 years.
Old 07-02-2007, 08:09 PM
Banned
m21sniper's Avatar
Use the lightest one you can find.
Old 07-03-2007, 09:10 AM
Heavy Metal Relocator
rhjames's Avatar
aluminum versus steel equals quicker revs.
you may balance issue to contend with as well. If you are disassembling the engine prior to installing it in to the US spec car, you might spend the bucks to have the internals balanced with the new flywheel. Other have argued against this, as 928 engines seem to be balanced from the factory quite well. You, however, are changing things, so there is really no way to tell if your bottom end will be balanced? For my money, have it balanced---then you know where you're at.
Make sure the one you order is specific to the engine you are putting it on....Carl will know what to send you.
Absence of Evidence, is not Evidence of Absence.
Bill Maher 8/4/09--- "I'll show you Obama's birth certificate, when you show me Sarah Palin's high school diploma."
Old 07-04-2007, 09:44 AM
Network Native
Danglerb's Avatar
I haven't decided on opening up the motor or just swapping it and doing the easy external seals and intakes. I want it running asap, so I am leaning toward quick swap so I can see basically how I like the stock Euro motor.
A machine shop should be able to balance the new flywheel the same as the old one?
I also wonder if I shouldn't have jumped in on the ATI damper group buy.
Old 07-04-2007, 11:36 AM
