Network Native
Danglerb's Avatar
Euro S intakes tubes several flavors
80 to 83 Euro S intake tubes (on the spider) are made for the screw in type CIS injectors. 84 to 86 Euro S are LH type injectors with barbed fuel ends with hoses, and come in two versions casting number ending in 1R and 2R. 2R the only difference I see is that cylinders 2 and 7 have a tapped fitting for a temperature sensor.
1R casting without tapped spot for a sensor.
This 1985 intake, note only #2 and #7 are 2R.
Shot of the sensor fitting, but without a sensor. #2 is where it would go though.
Old 04-03-2008, 09:19 PM
inventor
porken's Avatar
It's a temperature switch, to turn on the A/C fan at reduced speed, to cool the intake.
Slow speed resistor is in front of the radiators, on the US passenger side, white ceramic, round with two wires.
POWERED BY PORKEN
1986 928S3 AT grandprixweiß weinrot #1195
1988 928S4 MT polarsilberm sw/grau #1023
liftbars.com porken.com S300s.com
Old 04-04-2008, 12:30 PM
Network Native
Danglerb's Avatar
Thanks Porken.
Is it part of the engine front harness that goes to the 14 pin? *** pins 12 and 13.
Euro part I show as 928 606 218 00
US part as 928 606 217 00
but I never found any info on the switch value or a Behr etc part number.
I'm tempted to skip it for now, rather that swap out the intake tube, and look for a different way to make sure the intake doesn't get too hot. I wonder what header wrap would do for the intake tubes?
Old 04-04-2008, 04:15 PM
Make them look like crap?
Old 04-06-2008, 09:41 PM
RyanPerrella's Avatar
HA HA +1
Glad to see you've not changed your ways Dangler
1990 928 GT Black/Cashmere
Old 04-06-2008, 10:02 PM
Network Native
Danglerb's Avatar
So you don't like my drivers suit either?
Old 04-06-2008, 10:44 PM
MPDano's Avatar
Damn, that picture makes you look shorter than you are in person
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 04-07-2008, 06:08 AM
