Hey! Nice Rack! "Celette"
Looking for Tech info on euro "S"
My engine is a 5.0 Hybrid, 1980 M28/11 top end. I have it running but have a small issue with my CIS.
The engine is running rich. I tested the AAV. It checks out fine. I have an appointment to have the control pressure checked next week but I wanted to check to be sure I don't have some other simple issues like vacum leaks or a bad diaphram. (the thing on the side of the throttle body with the two hoses on it) The other thing with the rich condition is a high idle. The engine is idling at 1200 rpm's warm. I attempted to lower the idle by turning in the air screw on the throttle body but it made no change. So, on to my question. I looked through my manual and couldn't find a base setting for the air screw on the throttle body. Anyone have a clue?
Early Alien Sightings 914-M28/11 5.0 Hybrid (The Alien Sharkster) I think I smell your blood in the water WCC 04 done by the kids Who says Aliens only abduct people. |
I've not seen a base setting for the mixture and idle screws either but I don't see how turning the idle screw could not make any changes unless the plate is stuck open. It should move freely up and down and return to the up (closed) position at idle. If that's okay, then vacuum leaks would be my next guess, but wouldn't that make the idle high and lean since un-metered air would be getting in? Have you tried turning the mixture screw lean just a little (always finishing by turning lean to rich, iirc) to see if that makes a difference?
I know there's been times where I thought my car was running rich, but richening things up has actually improved idle. If it's too rich it should be hunting by changing RPM's up and down in a cycle as it idles, lean won't do that. |
Network Native
Idle means air is going in, find out where.
![]() Isn't there a mixture adjustment on the air meter seesaw catapult thing?
US 83 zinc metallic 5 spd, aka the nice car. Euro 85 black, 5 spd, the fast rough track car maybe car. SOLD Euro 84 red, AT, only car in garage in years, my parts car, soon to go last 7 years. |
Heavy Metal Relocator
Rich-
the vacuum limiter on the side of the throttle body was put on there to limit how fast the engine decelerates while changing gears through the neutral gate. it was eliminated in later MY cars. If you remove and plug the outlets, you have eliminated an area of vacuum leak concern. Other vacuum leaks can be checked with a Mighty VAC, or just plug the offending line individually-- test for throttle response or use a vacuum gauge to see if there is any change. The idle screw--on the front of the throttle body--is not really an idle screw. it is an idle mixture screw, not an rpm regulating adjustment (although it will change the rpm idle--I know, this doesn't sound like it makes sense). You will find a screw on the linkage (driver's) side of the throttle body. This screw, is actually for adjusting idle rpm's. Problem is, it's facing upside down and it is usually loctite-d or lock nut-ed. You can adjust it by using an allen wrench of the appropriate size, but this requires some fineness, or removing the throttle body-adjust-and then re-install. I looked through the FWMs and there is really no guidance as to where the base settings for CIS should be, other than pressures and O2 settings. --Russ
Absence of Evidence, is not Evidence of Absence. Bill Maher 8/4/09--- "I'll show you Obama's birth certificate, when you show me Sarah Palin's high school diploma." Last edited by rhjames; 03-19-2009 at 08:14 PM.. |
Banned
Uh oh~
You've probably seen these already, but they helped me a lot to understand how the CIS works.
http://forums.pelicanparts.com/showthread.php?t=185926&pp=20&highlight=cis+mixture+idle http://forums.pelicanparts.com/showthread.php?t=232089&highlight=cis I do need to get my junk into a shop with a CO meter and get it properly adjusted though instead of just playing it by ear. |
this guy souk is well versed with CIS, both of these threads are a valuable read.... --Russ
Absence of Evidence, is not Evidence of Absence. Bill Maher 8/4/09--- "I'll show you Obama's birth certificate, when you show me Sarah Palin's high school diploma." |
Yes there is. As I understand that adjustment-- you can press the air valve lever (sometimes called the barn door) down --at idle-- and it will richen the mixture. if you press it far enough to cause the engine to stumble, it is at it's too rich point. adjust the allen screw adjuster counterclockwise (a little at a time) until you can just barely press the lever down making the engine stumble. you're at a correct mixture level then, but not too rich. (If you bring the adjustment back clockwise, it will cause the engine to run lean.) --Russ
Oh ya, I forgot to mention, it has a low idle when I start it up in the morning and hunts for a little while. Then when it warms up it high idles. It's rich all the time.
Thanks for the links. I'll read all the posts. I have an appointment with a very saavy mechanic next week. He worked in Fla. at an import shop. Lots of ferrari's, Jag race cars, Lots of CIS Volvo's back in the day. Kind of funny I can build a franken car like the Alien and can't tune the CIS myself. Well I probably could but I have no experience with it except to turn a could screws with no result. Anywho, Thanks. I'll read up on it.
Let us know what the resolution is.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior 1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
No prob, I hope this helps. BTW, that avatar freaks me out every time
