Network Native
Danglerb's Avatar
Question Cheap A/F gauges and stock O2?
I found this Air Fuel ratio gauge on Amazon for $22 (ships free at $25), so I added some filler and bought one. Anybody using one of these cheap gauges with a stock O2 sensor?
http://www.amazon.com/gp/product/B000FJQWS0
Old 05-11-2009, 04:13 PM
MPDano's Avatar
Mike,
Weren't you of the ones telling me that a narrow band O2 reading ain't worth s%$t? Anyways, did a bunch of research on this and came to conclusion that I really need a Wide Band O2 Sensor and a Wide Band A/F Gauge. You can find them for around $200 as a set.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 05-11-2009, 05:47 PM
devilinblack's Avatar
Yeah, I thought Mike was beating that drum with me. At that price point I wouldn't expect much.
Stephen Powers
1978 US 5-Speed
New SoCal928.com Community Site
Old 05-11-2009, 05:54 PM
Network Native
Danglerb's Avatar
Leo doesn't run closed loop with his O2 sensor, which I think is key to one of these working.
BTW I have a wide band O2 sensor, but saving it to use when I borrow a wide band meter.
Old 05-11-2009, 06:00 PM
MPDano's Avatar
You can't just hook it up to the meter with the O2 only plugged into the Meter?
Old 05-11-2009, 07:35 PM
Network Native
Danglerb's Avatar
I'm not sure, but my conjecture is without closed loop control its going to show rich or lean, without a good indication of how much.
I don't plan to mount this one in my car, just hook it up for some amusement and then it can go into a different car. We can give it a try in Leo's car and see what it does.
*** If your question is about using a wideband sensor with a narrow band meter? The output of the wideband slowly changes voltage from lean to rich, and the narrow band doesn't change voltage much until a "trigger" point at stoichiometric where it changes abruptly. Unless a meter is calibrated for the sensor curves the voltage won't mean much.
Old 05-11-2009, 08:12 PM
MPDano's Avatar
Test away. The O2 wire terminates to the Center Console to nothing. Go for it!
Old 05-11-2009, 08:21 PM
MPDano's Avatar
This is the one I was talking about getting when the funds exist.
http://cgi.ebay.com/ebaymotors/AEM-GAUGE-TYPE-6-IN-1-WIDEBAND-UEGO-CONTROLLER-30-4100_W0QQcmdZViewItemQQ_trkparmsZ72Q3a1240Q7c66Q3a 1Q7c65Q3a12Q7c39Q3a1Q7c240Q3a1308Q7c301Q3a1Q7c293Q 3a1Q7c294Q3a25QQ_trksidZp3286Q2ec0Q2em14QQhashZite m4143893bccQQitemZ280305941452QQptZMotorsQ5fCarQ5f TruckQ5fPartsQ5fAccessories
Old 05-11-2009, 08:51 PM
Imo000's Avatar
Unless you are running boost, why would you want one?
Imre
1985 928S, 5-Speed, DIY Supercharged http://norcal928.org/DIYSC/index.htm, H-pipe, 12.8sec.
Old 05-11-2009, 09:01 PM
Network Native
Danglerb's Avatar
On my my 85 Euro I intend to sharktune it, and I don't think the Sharktuner on the LH2.2 can pick up A/F directly. For the other cars, just curious, maybe try some tuning with the more limited controls.
Old 05-11-2009, 10:02 PM
MPDano's Avatar
CIS, not computer controlled. I would like to get my A/F spot on. Plus I got two holes I need to fill on both sides of my clock in the Center Console The other I was thinking of an Oil Temp Gauge.
Old 05-12-2009, 05:59 AM
Network Native
Danglerb's Avatar
Oil temp is fun, literally hotter the oil the more fun you are usually having.
Old 05-12-2009, 12:37 PM
DMRK's Avatar
You could fill the other hole with a pyrometer. EGT goes well together with A/F to tell you what is going on.
Dave
82 928 Weissach #14
Old 05-14-2009, 08:41 PM
