Seals and rubber as well.... cha-ching, cha-ching, cha-ching.... it never stops....
i have a set of "o" rings available for the distributor is you are interested.
autowerks9 PCA SINCE 1991, REISENTOTER 1982 EURO 928S 320HP MEDIORMETALIC/BURG. 1987 944S- GT3 BODY CONVErSION RED/BLACK( sold ) 2003 MERCEDES E500 Sport "Einfarbig" |
His Distributor already has 100% new O Rings donated by Raymond (rjm65). We think the problem is the sealer he used.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior 1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Well, Blythe? How did the rebuild go?
I sent you a pm. I'm not sure Leo. I'm POSITIVE I did it right. But still, the car won't stay running! I took a line off the injector, and a buddy watched it while i turned it over and he said there wasnt much fuel coming out. I'm going to have to check the fuel pressure going to the f.d. I have to go buy a pressure tester somewhere. Is harbor freight open today? the one in chula vista, think they have one?
Harbor Freight is open on Sunday, not sure if the one in El Cajon is closer to you or not. I think DanglerB had mentioned they don't have the proper adapters.
Did you make sure the barrel was really clean? The slits inside the barrel are almost invisible to the naked eye. |
I saw the slits, they were obtruded. Everything was right, i'm sure. the prob has to lye somewhere else?.....
EDIT: They were UN obtruded Last edited by BB500; 06-07-2009 at 11:47 AM.. |
Yeah, that's from the outside of the barrel where they have an oval shaped insert that the 8 o-rings sits over.
But if you look at the inside of the barrel there are 8 corresponding slits. |
Network Native
HF 20% coupon
http://www.harborfreight22.com/r2/r4.asp?r=4912_213372&i=Q2928605H004&cust=00031320058&keycode=0000& I think the Master set has everything, but they have easy returns if you can't check it out while your at the store. |
Thanks mike!!!
I'm curious as to why you haven't just gotten the proper CIS kit by now if you think this is fuel related?
There is a cis kit? To be honest with you, I never should have touched the f.d. My next step is to check the fuel pressure going into and out of the f.d.
I'm going to get a pressure tester today and post the results, and see where things from there. |
Drop that damn tank!
Network Native
Fuel distributor on ebay right now for I think $75, but its as is.
Unless you or someone you trust can verify it is functioning as should be.
Network Native
Lfausty is selling it off the 78 that is getting parted. Car ran as far as I know.
I have bought a bunch of stuff from her (Lisa)...every time i get it...she has been honest with me....couldnt fault her!! ...buy it!!
John ......... 1978 Porsche 928 5sp LSD 1982 porsche 928 5sp LSD |
