-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=15)
-   -   What Degree Thermostat? (http://forums.pelicanparts.com/showthread.php?t=487705)
Danglerb 07-29-2009 12:16 PM
The Evan's stuff has less heat carrying capacity at the same temperature than coolant 50/50 has so for the "same" level of performance at factory temperatures the radiator would need to be larger. It may be the schizz for new stuff, but retrofit to cure the non problem of the factory system is going to be a mess.
There is no need to go looking for trouble with a 928.
