Crumpler's Avatar
Mock Up Fan Shroud
Ok, I will admit I was tired of cleaning electrical contacts.
I started messing around with more sheet metal.
I have been looking at different profiles for fan shroud and air intakes and took it a step further.
This was the initial vision. It would be a few pounds back on the car and more to unbutton for access. Probably no substantial benefit to air flow, but man I do like the look...
Dave
1986.5 Manual Blk/Blk
Old 11-02-2013, 11:46 AM
Kool
AirtekHVAC's Avatar
I like that as well!!! Will it cool better, or worse?
Ron
1978 5sp (#30) project-Wreckscue, 1979 5sp Euro Project
1982 5sp resto project, 1985 Auto S3
1984 Parts car (the fire car) 1987 s4 (parts, or maybe project)
(Yes, I now have 4 project Sharks)
Old 11-02-2013, 11:49 AM
Crumpler's Avatar
I won't know until "Beta" test.
Under the hood, the profiled edge is slotted. I doubt that is by accident, may be disperse heat? Anybody know?
Dave
Old 11-02-2013, 12:05 PM
Network Native
Danglerb's Avatar
Looks great, but I think wrong idea. Rubber strip going across above the blue tape seals to the hood when closed, so this plate does?
Could be a bear if the hood release cable breaks.
Porken does a "mat" of the nitrile foam sheeting that goes under the intake scoops and covers the top of the radiator and AC coil for a cold air input. I'd go a step further and run the mat down both sides of the gap between AC coil and radiator.
Functionally I think maybe more gains to be had from sealing the bottom.
Old 11-02-2013, 07:07 PM
Crumpler's Avatar
Prototype is done.
Those are good points Danglerb, the functionality of the plate is pretty shakey.
This will probably only be a cosmetic piece. Although who knows, if the insertion of a Porken TQring can change air flow -- maybe this would have some merit. This does keep air from bouncing off the deep-lipped insert on the underside of the hood.
I'm going to take her out later and see if any temp. differences, etc.
Dave
Old 11-03-2013, 06:57 PM
Network Native
Danglerb's Avatar
Cosmetically I think it has to go under the lower hood latch, or at least flush with it.
Don't get me wrong, I "like" the look, but I don't see it as a cold air intake mod.
Old 11-03-2013, 09:19 PM
laneyamps's Avatar
I think it looks pretty cool! Looks like a "partial hood" hehe
84' 928S Black/Black
Old 11-05-2013, 01:51 PM
Porsche 928 Fanatic!
Looks pretty cool, but the current hood & wetherstripping already does what this does mechanically
Webmaster - www.GreatWhite928.com
250+ 928s for sale at all times!
Old 11-10-2013, 05:02 PM
