928 s4 cut out while driving over speed ramp
Hi
Driving my s4 low on fuel and drove slowly over a speed ramp and then the anti lock light came on and the car came to a hault. Suspected fuel so put 20 litres in. The car will just about start up but cuts out after 1 second or as soon as you attempt to give any throttle. Just towed it home as to late to mess but any ideas appreciated Thanks Dave |
Banned
Well, if it starts at all, the fuel pump is working.
LH-Jetronic: What will cause this system to start to work, but then shut down. It sounds like it is giving start enrichment, but as soon as that disappears...the engine stops. The long and short: You've probably a wiring issue, and I suspect it is on the central electric board under the passenger foot well. Hmm.... now that I think of it...the fuel pump may be working, but it is possible that the relay is burnt/overheating/funkalated, and as such won't allow the pump to run. Have you tried a new relay? We're with you! Folks, it's time to circle the wagons- N |
1982 928S euro M28/11 That criminal under the hood is a really bad influence on me: "hey...what about another 1000 rpm? And you know, we're doing 75...but I can go 100 and you'll hear my beautiful voice a lot better! Lets go baby..." dammit! I'm such a slut~ N! -Normy |
Were ther ANY the less bit odd behaviors before this?? Some electrics working when not on, windows not rolling down some times, ect....
No all was working fine,
car going very well.... going to check the basics spark and fuel later, test the fuel pump relay.. Thanks |
Your primary fuel pump has probably failed. Exact same failure happened to me in the same way.
If you're lucky its just jammed and you can clear it by applying voltage both ways in short bursts, running it both forwards and backwards. The in-tank pump will pressurise the system giving it enough gas to turn over once or twice, then it runs out of fuel and dies as it can't supply enough to feed the engine.
Various manual S4's |
Great
Whats the location of the primary fuel pump? |
Backside of the fuel tank - there's a metal cover with two 10mm nuts (M6) that are just above the rear bumper. You can remove the pump without lifting the car up in the air.
Pull the cover off, and you'll find the pump and fuel filter. Annoyingly, the fuel filter is on the other side of the pump from the tank, so any sediment and crap in your tank gets to bust up your pump before its filtered ![]() Then:
Various manual S4's Last edited by Xlot; 10-15-2009 at 05:39 AM.. |
