Petie3rd
just a note to turn the cams use the BIG nut portion not the cap screw
IIRC the big nut is a 30mm, you can inadvertently loosen the cap screw and then it will fall out
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats |
inventor
It could be the pics, but it looks like the cam gears are worn out, shiny from the coating having been worn off. The oil pump gear looks new.
It also looks as if the belt is HTD/round tooth (HTD is '83-up). The gears appear to still be square type, however.
POWERED BY PORKEN 1986 928S3 AT grandprixweiß weinrot #11951988 928S4 MT polarsilberm sw/grau #1023 liftbars.com porken.com S300s.com
