928 questions
First, the upper idler pulley for the timing belt, it does not seem to contact the belt? Is this just for slop at high rpm?
Second, the plastic cover over the wiper motor, under the hood, it goes across from one side to another, where would I find a new one? other than a dealer. |
Correct the small pulley over the tensioner pulley is just for belt slack.
vendors for the rear wiper cowel cover are: ..here on pelican !! site sponsor 928specialist.com..spe3ak with jeannie or JR ************. speak with rodger |
the top roller is to control belt flutter as the engine expands from cold to running temperature.
If you do a bit of searching 928International is having its yearly half price sale in December all used parts are half price good luck |
Cowl panel cover is so flimsy a new one is the only way to go. If yours is missing be sure to get all the leaves and junk out of the cowl area.
So a dealer is my only option I guess. |
Fred see post #3
Usually 928Intl has good used parts its worth a check |
| All times are GMT -8. The time now is 08:11 AM. |
