Banned
Normy's Avatar
What I think you are running into Neil is a car that simply runs lean. I suspect that this is typical on the early LH cars, in particular the 2-valve engines.
What is your fuel pressure like? It sounds like it might be a bit low. I mounted a rising-rate fuel pressure regulator on my '85 S2 5 speed [basically the same car as yours] and then set the MAF to a very lean setting. After trial and error, I managed to get the car to run 14.7 at idle, but around 12:1 at full throttle, all the way through the rev range. My rear tires only last a few thousand miles as a result~
I'd check that fuel pressure first.
Good luck-
N
Old 03-16-2010, 04:52 PM
Recovering dismantler
neil30076's Avatar
Good luck-
N
I'm leaning ( no pun intended!) to fuel pressure as well - others have suggested pulling the vacuum from the FPR which should raise pressure and see what that does - simple test -
I'll report back
Neil
2009 Mini Cooper
2004 Mercedes CLK500
2024 Subaru Outback Touring XT
2020 Entegra Coach
Old 03-16-2010, 07:20 PM
neil30076's Avatar
next suggestion, please!
I tried clamping off the fuel pressure regulator vacuum line as suggested - made no perceivable difference. So, I recalled the 'brain' has a link that is not normally connected that is used in areas of bad ( low octane) fuel to alter the map in some way - I'm assuming the link retards the timing for low octane fuel on the high CR engine to prevent pinging, I plugged them together on 89 gas. after a run the A/f at idle went down to 14 .1, from the previous rock solid 14.7 - at 1500 - 2500 there is not as good an improvement, and its still lean - 15 .5, down from the fail ratio of 16.5 - -
Am I making the right assumptions, any more suggestions -
Neil
Neil
2009 Mini Cooper
2020 Entegra Coach
Old 03-30-2010, 12:01 PM
MPDano's Avatar
Neil
Neil, you don't think it will pass on those changes? That's real close to 14.7
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 03-30-2010, 01:11 PM
neil30076's Avatar
I'll probably go give it a try - i don't have a lot of options left to get the mixture lean - I swapped out the MAF, exactly the same, so i think i can rule that out -
Any other thoughts - anyone????
Neil
2009 Mini Cooper
2020 Entegra Coach
Old 03-30-2010, 08:50 PM
