Need a smog doc, stat!
My 1984 Euro S refresh project, first time driven in over 2 years, just refreshed everything top side of engine, hold vacuum perfectly, no leaks , etc, etc.
Failed smog on high NO ( see attached). I'm getting ready to hook up the LM-1 and CO tester, high NO with other readings in range suggests it is set to lean, anyone have an opinion. http://forums.pelicanparts.com/uploa...1267920108.jpg |
Are you sure the O2 sensor is good?
Neil--
Hope you can read my RL comment. Plus, you may want to look and be sure you have copper plugs (no plats or silver), and maybe one or two steps colder than original. Plats are typically a hotter tip compared with copper of the same heat range so theycan be self-cleaning; the plat is more durable so the high tip temp is what they are designed to do. Then drive the car long and hard, the proverbial Italian Tune-Up, to get any oil resdue in the intake flushed through and out before you test. Roll it right oto the rolers when you get there, so no parking-lot cool-down of the cats. |
Hi Neil,
Here is my results after putting a new Cat and it was running Super "Lean" when tested. It doesn't seem that your issue is a Lean A/F. Are you sure it wasn't "Rich?" http://forums.pelicanparts.com/uploa...1267940664.jpg |
you may need to reset the MAF
IIRC a setting of 167 ohms or so seemed to make the car run well you can check the MAF setting at the computer connection get on RL and search for MAF setting by PORKEN |
Also, isn't this for your Air Force Daughter? If so, check the Smog Requirements (if any) in the State she is Stationed at. |
Thanks everyone, yes Dr B, I check the RL post -
- Leo, yes the car was a great deal beacuse of the smog failure, and they handed me a new - yes new - MAF that they had not installed! And yes, no smog check where the car is going, so not so critical - but i would like it to pass anyway :-) . Stan, the old MAF setting was around 470, the new one is set s 700 - so some more investigaiton is needed, as soon as i get the AFR meter set up i'll have a better idea. thanks all for your commenst, i'll report back. |
Update - need a smog doc!
Update - I have the wideband O2 sensor and LM-1 ( Innovate) installed - ran until at normal temp, at idle AFR is right on 14.7. As soon as i open up on the gas it jumps up to around 16.2 way lean -- off gas - back below 14 .3 for a second or so, then right back to 14.7. Swapped out MAF with a new one PO gave me, and exactly the same, MAF adjustment is now right at max - 1,000 ohms. Put my vacuum gauge on vac lines, holding good when idling, drops of course when i hit the gas, but comes right back - gas sniffer ( gunson) says 3.5%.
Whats next? |
Leo, I have the whole setup - multi channel input, rpm adapter, thermocouples, logger, digital display -etc- I can see it jumping around in real time and also damped so it's a more readable value.
The car runs like a rocket, easily spins wheels on take off - and lots of power, I'm concerned about the lean condition at anything other that idle - that's my main focus right now. |
what happens when you adjust the MAF to about 170 ohms??
As i adjust the maf resistance down it gets much worse - goes to about 17.5:1, starts to run really rough and stumbles as i give it gas.
I noticed the plugs are W8DC's, i recall a euro should have w7's - can that be the problem - plugs not hot enough? |
How do you check the timiing on a dual dizzy Auto 84 Euro? The smog check says the timing was 21deg - but doesn't say at what RPM.
well I hope I don't sound new, but I am to these cars so take what I say as just trying to throw some ideas out there.
If you run more advance on the timing your NO would get worse, correct? I believe a real hot burn produces more NO If the timing can be retarded to say 19 from the 21 (that must be full advance BTW) it may help second thought If this is a problem car or a problem from before ..... has anyone put the wrong control unit in it (ECM) I'm sure you guys have thought of all this anyway. Seems like some well experienced post maybe I stirred some other thought |
Dual Dist makes no difference, timing is "set" by the brain using a crank sensor, just put the pickup clip on the cylinder 1 wire and read the marking on the dampener. Use the rpm etc required for your model.
Neil, is this L-Jet?
84 Euro is LH not L, off the top of my head about 10 BTDC at idle.
What I think you are running into Neil is a car that simply runs lean. I suspect that this is typical on the early LH cars, in particular the 2-valve engines.
What is your fuel pressure like? It sounds like it might be a bit low. I mounted a rising-rate fuel pressure regulator on my '85 S2 5 speed [basically the same car as yours] and then set the MAF to a very lean setting. After trial and error, I managed to get the car to run 14.7 at idle, but around 12:1 at full throttle, all the way through the rev range. My rear tires only last a few thousand miles as a result~ I'd check that fuel pressure first. Good luck- N |
I'll report back |
next suggestion, please!
I tried clamping off the fuel pressure regulator vacuum line as suggested - made no perceivable difference. So, I recalled the 'brain' has a link that is not normally connected that is used in areas of bad ( low octane) fuel to alter the map in some way - I'm assuming the link retards the timing for low octane fuel on the high CR engine to prevent pinging, I plugged them together on 89 gas. after a run the A/f at idle went down to 14 .1, from the previous rock solid 14.7 - at 1500 - 2500 there is not as good an improvement, and its still lean - 15 .5, down from the fail ratio of 16.5 - -
Am I making the right assumptions, any more suggestions - Thanks Neil |
I'll probably go give it a try - i don't have a lot of options left to get the mixture lean - I swapped out the MAF, exactly the same, so i think i can rule that out -
Any other thoughts - anyone???? |
| All times are GMT -8. The time now is 11:58 AM. |
