interior dome lamp
On my black on black 85 928S the area around the interior dome light has warped a bit. As a result the interior dome light does not stay in very well. It also seems to me that the 2 brass points on the ends need to be in contact with the metal of the roof for a ground.
Has anyone had this problem and made a repair or modification?
(without removing or replacing the headliner?)
Old 06-28-2010, 12:58 PM
Maleficio's Avatar
Maybe you can build up the hole with conductive metal tape?
Old 06-28-2010, 01:14 PM
tlsmith1999's Avatar
You do not want the metal part of the lamp to touch the car. The lamp should have three wires that attach to it, two grounds and a hot if i remember correctly. Ground is applied on one wire when the door is opened, and constant on the other. You will want to disconnect the bttry or pull the fuse when you work on it, as the positive is always hot.
Tim
White '89 S4 A/T, Blue Int
Kaschmirbeige '78 5spd, Cork Int - Featured in High Heels & Hot Wheels 2010 calendar!!
Petrol Blue '79 EURO 5spd, Black & brown Pasha Int
Old 06-28-2010, 01:31 PM
MPDano's Avatar
Try this Mod:
http://forums.pelicanparts.com/porsche-928-technical-forum/466282-dome-light-changeout.html
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 06-28-2010, 01:56 PM
What model vw would this light come from?
I am trying to find a black one on eBay
Old 06-28-2010, 05:42 PM
Maleficio's Avatar
I got a new one from ****** auto for $30.
Old 06-28-2010, 08:10 PM
MPDano's Avatar
I just did a "vw gti dome" search on ebay and came up with a ****load of them. Only a couple black ones though.
vw gti dome items - Get great deals on eBay Motors items on eBay.com!
Old 06-29-2010, 07:40 AM
