What's the correct parasitic draw
The Parasitic draw on my 89 / 928 starts at 1.04 amp, then after 6 sec drops to 0.43 ma then after 10 sec drops to 0.35 ma
Dose this sound right. I found my drain BTW, the rear defog was staying on. I pulled fuses till it went out. I also pulled the door light relay for the time being.
Names Brad, Canada, Fort McMurray. Car is a 1989 928 5L AT from Japan, 17" rims, 95,000 k vin#WPOZZZ92ZKS842476 |
You should not have more than 0.04A of drain on the battery.
