Rear Wing Strength?
In an effort to combine my two fav hobbies, I was goofing around one day and tried a series of combinations to put my Thule bike rack for my Jetta on the 928. Well I can get it to work provided I run the strap over the rear wing. there isn't much stress on the wing as the bike weight (25 lbs) is resting on mainly the two straps running up to the hatch. So what do you think? Does anyone know how much stress the rear wing can safely take?
And yes, I know it's an 86 Raleigh Technium 440 and the rack is worth more than the bike, but the car and the bike are from the same era....
Petie3rd
with the wing as old as it is and seeing how its attached i wouldnt put anything on the wing cept a beer and hoagi and some chips.
YMMV but there have been others reporting the studs ripped out of the wing there are 2 on each side. try removing the wing and see how that works use PB blaster on the screws
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats |
European Shark
But at highway speeds, the wing is pushed down by about 50lbs, so I really don't see the problem? If you don't go much above 60, it should be fine..
1978 Porsche 928 Euro 5spd. Silver metallic/Black 1986 Porsche 928 S2 Euro 5spd. Meteormetallic/Grey. *Crashed* Owning a 928 is risky business - but sometimes you just gotta say "what the fudge". |
That's way too nice of an S4 to be messing with straps over the wing. Just remove the front wheel and seat and put the bike inside the hatch.
Plus, why would you want to display a Raleigh on a Porsche 928, it should be a Cannondale, etc
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior 1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Petie3rd
and when you hit a bump at 50 mph guess how much the load factor goes up with an extra weight on the tail..
I would figure out a way to put the bike into the car, the less things you have contacting the painted surfaces the less damage you will do to your car
Have a normal body hitch installed and you can get a bracket made to hold a bike. Your make shift set up is not going to work well and may cause damage to the car. Porsche did say something about towing in the manual, check it out.
1986 928S 32 valve engine All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires. Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster |
Rack comes off tomorrow! The bike barely fits in the hatch w/front tire removed, but the new (to me) bike (a Trek) doesn't fit at all. :-(
I'll explore a hitch. This car is my keeper and I don't want to dork it up. I know they make a hitch for it somewhere because I saw more than one pulling a little two wheeled utility trailer while I was in Germany. The trek is lighter, a tad uner 20 lbs... ;-) |
