MPDano's Avatar
Help me ID this Disconnected Part
What is this that is disconnected?
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 03-09-2011, 06:39 PM
928: Serial Enabler
I think it is the freeze sensor for the evaporator for the air conditioner.
If you remove it, it will have a long thin probe attached/
84,85,86 928 cars
Old 03-09-2011, 06:51 PM
Recovering dismantler
neil30076's Avatar
PET illustration 813-30 pos 35A, Temperature switch 928 613 133 00
Neil
2009 Mini Cooper
2004 Mercedes CLK500
2024 Subaru Outback Touring XT
2020 Entegra Coach
Old 03-10-2011, 07:55 AM
MPDano's Avatar
Do you have one on your 928's Neil? If so, is yours disconnected too?
Old 03-10-2011, 09:55 AM
Petie3rd
Mrmerlin's Avatar
that part is called a freeze switch it is used to shut off power to the AC compressor when the evaporator gets to freezing temperature,
this will preven the evaporator from freezing up, it is adjustable via a small phillips screw next to the male elex connector pin.
NOTE you only need to turn it 1/4 turn or less .
You can test it with a glass of ice water,
remove screw holding it to the duct then pull it straight out,
There is a brass tube filled with oil that goes into the fins dip in water and listen for a click this tells you it functioning,
make sure to measure the water temp so you know what the open/close temp is. you must also fit the cowl cover so engine heat will have less of effect on its operation
Old 03-10-2011, 10:30 AM
neil30076's Avatar
81 doesn't have one, I know the 84 did and it was connected, and the 86 does, and its connected.
Neil
2009 Mini Cooper
2020 Entegra Coach
Old 03-10-2011, 10:39 AM
MPDano's Avatar
Ok, looks like I need to look for some hanging wires somewhere near there.
Old 03-10-2011, 10:41 AM
