winshield wiper probem
I have an 82 Euro S that the windshield wipers stayed on all the time unless I pulled the plug in the cowl. I am trying to get it ready for inspection so I was messing around with the plug and the 6 connections in it. I found that when this green wire is connected the wipers stay on and with it pulled the wipers work except for setting 1(slow) and setting 4(delay wipe). I have left the green unhooked for now but wonder what the problem is. Any suggestions? Relay? Gunarhttp://forums.pelicanparts.com/uploa...1299705544.jpg
Funny, mine was blowing fuses all the time I put the Windshield wipers on, ended being a shorted wire where the AC Guy was removing the Expansion Valve in that area. He must have been having a hard time removing it and his tool slipped and smashed the harness there causing a short.
Probably didn't help any but thought I would share my story. I can take a pic of my wiring right there and see if the PO may have crossed the wires around. |
I had the bad rear resonator cut out and the pumpkin was already missing. All it has now is the front dual in/out muffler.
Here you go Gunar. I also flipped the connector so you can see both sides:
http://forums.pelicanparts.com/uploa...1299724682.jpg http://forums.pelicanparts.com/uploa...1299724687.jpg http://forums.pelicanparts.com/uploa...1299724692.jpg http://forums.pelicanparts.com/uploa...1299724696.jpg http://forums.pelicanparts.com/uploa...1299724701.jpg http://forums.pelicanparts.com/uploa...1299724706.jpg |
| All times are GMT -8. The time now is 06:20 PM. |
