clutch noise, oh no!?
I just joined forum so please bear with me. My '79 928 has a clutch related noise at idle. At first I thought it was a water pump bushing or alternator bearing starting to go out, then I noticed that it went away if I barely depressed the clutch pedal. Pedal has no freeplay, clutch and throwout has 9,000 miles on it. It shifts smoothly but I also noticed previously that I could feel pulsing in the pedal (on occasion) when it was depressed to floor. If anyone could share experience it would sure be appreciated. I sure would like to know what is going on in there. Thanks. Phil from N. Idaho.
Old 04-22-2011, 02:48 PM
jdill
im not positive phil what your noise is but i think you need to start by putting some free play into your pedal, check the manual for procedure ,its pretty simple
Manuals
79 928 euro -lint green/black leather 5 speed
Old 04-22-2011, 05:07 PM
jdill
oh ya, go to table of contents, then transmisions,then clutch operations,you should be all set after that
Old 04-22-2011, 05:12 PM
my noise
thanks. I will try navigating site.
Old 04-22-2011, 06:23 PM
where is 'table of contacts' on this site
Old 04-22-2011, 06:26 PM
jdill
scroll down to 928 table of contents w/links click on scroll down to transmisions-clutch adjustments
Old 04-22-2011, 07:03 PM
