Maleficio's Avatar
Awesome pic of a 79.
1982 Porsche 928, Auto, 4.5
http://i72.photobucket.com/albums/i166/hethaerto/928Mist2.jpg?t=1305333945
Old 04-21-2011, 07:57 PM
MPDano's Avatar
Yes, great color too. I just hate the original front ride height though. PD's rule!
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 04-21-2011, 08:05 PM
gbgastowers's Avatar
My thoughts on that ride height. Having my car at that height (now that I have those spring spacers in) is much less stressful. When it was lower I was bottoming out easily and front tires were rubbing when I turned sometimes. Still have a lot of worries about how bad it's running. Going after ignition now. New plug wires,cap,rotor and spark plugs coming from Roger. Alternator and volt gauge are working now. Getting fire out the tail pipe when I let off the gas and it backfires. I lowered my mirror tonight to watch it. Maybe I shouldn't drive it till I get the problems fixed but I can't resist. Always testing changes out.
82 928 Euro S 5 speed, sport seats,Moss Green/Champagne 04 996 C4S conv tip Polar Silver/Metropol blue
Old 04-21-2011, 09:34 PM
Maleficio's Avatar
You may have bad fuel regulators allowing fuel past the vacuum diaphragms and then sucked into the intake unmetered.
Old 04-22-2011, 06:02 AM
Backfiring out the exhaust is normally caused by ignition timing, vacuum leak on the distributor retard line or line to the decelerator valve, or a busted diaphram in the decelerator valve itself.
Dennis
Old 04-22-2011, 06:10 AM
Maleficio's Avatar
I may have a bad decelerator valve.
Old 04-22-2011, 06:39 AM
Maleficio's Avatar
Landseer, you nailed it. I finally found the ground you were talking about. It's not behind the air pump, but under the air pump control.
I had the car running, barely touched the valve body, and the car instantly stalled.
I then noticed the brown harness wrap under it and thought "That's it!".
Found the screw halfway in. Ran it in good and tight, car now lights off quick and runs great.
Thanks for everyone's help, and a HUGE thanks to Landseer!
Awesome work!
Old 04-23-2011, 08:57 AM
Maleficio's Avatar
Stereo works properly now, too.
Old 04-23-2011, 08:58 AM
Dean_Fuller's Avatar
The force is strong with Landseer.
Old 04-23-2011, 09:03 AM
Maleficio's Avatar
Old 04-23-2011, 09:23 AM
MPDano's Avatar
We need top nickname Landseer "Mr Ground" as he's got this part licked. Among other things too. Way to go!!
Old 04-23-2011, 09:57 AM
Maleficio's Avatar
:d
Old 04-23-2011, 10:11 AM
Recovering dismantler
neil30076's Avatar
Nice find, and at last a cheap fix.
Congrats
Neil
Neil
2009 Mini Cooper
2004 Mercedes CLK500
2024 Subaru Outback Touring XT
2020 Entegra Coach
Old 04-23-2011, 12:17 PM
Maleficio's Avatar
Yeah, can't get any cheaper than tightening a screw.
But I learned a buttload more about this car, gained a few very cool tools, have extra relays on standby now, and the car's running smoother than ever, and starts with just a blip of the switch.
Old 04-23-2011, 12:27 PM
928: Serial Enabler
Exactly how I learned.
Trying to fix the first one.
84,85,86 928 cars
Old 04-23-2011, 01:14 PM
Maleficio's Avatar
I've got a good mind to route that ground wire to some place visible and easily accessed.
Old 04-23-2011, 01:47 PM
Maleficio's Avatar
After I got it running, I went ahead and replaced the pax fuel regulator and the fuel damper.
I ordered the left and right regulators, but the eBay dude sent me one regulator and a damper. I didn't realize this until today when I began the job.
I was like "Perfect!", because I thought I still needed to acquire a damper. The pax regulator leaked fuel out the vacuum port, but the driver regulator did not, so I chose to replace the pax one. After I had finished the replacement, I went ahead and replaced the fuel hose on the driver regulator, too. Both hoses were ROTTEN!
The car now idles too high. I'll adjust that later.
So, in this process, I've replaced:
fuel pump relay $50
fuel injection relay $25
temp II $25
fuel filter $15
pax regulator $30
damper $35
Not bad, I guess, considering I was planning on buying another L-Jet, ignition switch and fuel pump.
Old 04-23-2011, 01:56 PM
928: Serial Enabler
Excellent. You've researched wisely
When Neil gets to the east coast we should get together in VA Beach area.
84,85,86 928 cars
Old 04-23-2011, 02:02 PM
928: Serial Enabler
Here's some from today. The dog weighs 145lbs. Wish she had less of an attitude though.
I paid $2000 for the front 86. Had 73K miles.
84,85,86 928 cars
Old 04-23-2011, 02:06 PM
Maleficio's Avatar
That would be very cool.
Old 04-23-2011, 02:14 PM
