i took off my grill to sand and paint it, i found a little yellow wire sticking out and cant find "the other end" i think its to my fan? dont know,can anyone tell me what it is and where it goes? its coming off of the bottom of the front support next to the fan in the nose....
Can you post a picture?
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior 1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
i have it on my phone and cant find the wire to upload! 614-940-8425.....? txt it to u?
little yellow wire?
thanks!
Here's your picture.
_ 1985 Porsche 928S "USA" 5spd Black, Tan Interior |
what is that too?
Total newbie here but having looked at a ton of wiring behind the dash recently, both wires look solid yellow. Looks like something aftermarket possibly. Does the wire die into the original wiring harness?
not sure? havnt had good weather to clean and inspect
is it the original fog light hook up? its wired to a toggle switch on the lower dash panel
Not sure but you're asking the right group here. You'll get your answer. Looks like a bale of hay stuck in that grill!
no kidding!
N. Central Florida
On my S4 I had a temp sensor located at that front corner of the radiator. Take a look under the debris and see if you have an electrical sensor there.
Is your Temp Sensor hooked up? It's that Round thing in the right of your picture?
little yellow wire?
ill check it out after i can clean the hay field out! thanks
little yellow wire?
finally got some time to clean out the farm! the temp senser is hooked up and fine,but the two yellow wires dont run to anything i can find....there is no other "end" to connect to....any ideas?
There "has" to be an end to that wire. If it's not connected to anything, then pull it out and move on.
little yellow wire
is it the fog lights hook up? dont want to yank it out if it operates something!
SharkHead
Not many yel wires that come and go from sendors/devices on the 928. The right headlight has a yel and a wht to it and brn for ground. Most sendors are two color.
What does not work up front??
'79 928, 85k Opal Metallic '99 BMW 540i, 97k Titanium '72 BMW 3.0 csi, 85k km (euro Deutschland '82) Taiga |
little yellow wire?
its got me stumped? everything works up there,cant tell where its coming from,its running under the round temp sensor and keeps going....no clue
SharkHead
It does appear (or is close lookalike) to be a rubber Porsche wire sleeve which the wires terminate in...what type of termination are they?? flat spade male or female or bullet connector m/f??
