-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=15)
-   -   how to remove headlamps (http://forums.pelicanparts.com/showthread.php?t=605615)
txhokie4life 04-28-2011 04:09 PM
'82 Euro 928
Want to remove the headlamps to remove condensation.
Pulled the plastic shroud off == not sure whats next
and didn't want to dive in un-informed.
pointers?
thx
mike
MPDano 04-28-2011 05:25 PM
Well the shroud is the hardest part. Is yours the H4 lamps? The standard ones here in the US use that chrome trim ring in front that hold the lamp in place. Not sure on the H4.
txhokie4life 04-29-2011 09:45 AM
No -- mine are the European ones without a chrome ring.
I've got the plastic shroud off -- just 3 screws.
I'm trying to figure out how the headlamp is connected
to the holding mechanism.
I see a couple of alignment screws and a few springs.
just not sure what comes undone to free the head lamp from the assembly.
Mike
Dean_Fuller 04-29-2011 01:12 PM
This is a pic I pulled from another site. The headlights attach similarly. You can see a U shaped bracket ( black) and 4 Philips head screws that hold the assembly to the U bracket. At the bottom there is a snap in stud/ ball fitting that stabilizes the unit..that will pull straight out.http://forums.pelicanparts.com/uploa...1304107952.jpg
Dean_Fuller 04-29-2011 01:15 PM
Here is a shot of the Headlight out.http://forums.pelicanparts.com/uploa...1304108119.jpg
txhokie4life 04-29-2011 02:04 PM
sweet -- that is exactly what I wanted to see --- thanks!!
Mike
txhokie4life 05-01-2011 06:54 PM
Wow that was easy!
Also note there is a connection on the bottom with a ball and socket that pops off.
Not sure its function.
Mike
Dean_Fuller 05-01-2011 06:59 PM
Its just to stabilize I think. Help hold the light from shaking at speed and bumps. The 3 point rule as opposed to 2 points of contact..
