oil leak 1985-928S
i have an oil leak from somewhere behind the oil dipstick.
help ![]()
Pull the cover and have a look. Being on that side I'd guess crank seal or else maybe coming from the timing belt tensioner. How much oil is it? Fresh or old?
928: Serial Enabler
Can you show a picture of the whole top of the engine for perspective.
I think I know where its coming from.
84,85,86 928 cars |
a little behind this position, but low
under and behind the dipstick
928: Serial Enabler
Indeterminate on yours. Looks like new boots and clean intake, so maybe you cleaned away the telltales.
The crankcase breather hoses on the 85/6 cars are known to decompose if original. One of them tends to break near the passenger side base of the oil filler snout. Then it mists oil. It tends to spray right where you show, plus, aross the engine and hood in a trail back to the firewall. I've seen three where a hole or crack has occured where the hose attaches deep at the base of that snout. Only way to get to it is with an intake refresh. Not sure your car's history, but the boots on the organ pipes look very fresh. I'd remove the passenger side plenum (easy) and look at the condition of the two hoses as they attach on the cam covers, buried under that passenger plenum. Squeeze them and see if they are decomposing. Other source could be that black plastic cap on the front of the cam tower, passenger side. Or the cam cover gasket (need a little silicon in the corners / maybe somebody didn't use it during gasket replacement?). Also tensioner oil leak, but usually its lower. Kinda doubt its serious, ie, at the head/block joint. Possible. Unlikely. Thought your car was red --- had you confused with somebody else.
84,85,86 928 cars Last edited by Landseer; 05-02-2011 at 02:17 PM.. |
Gonna get under for better view
I have tarp under it to help pin point |
I have had the side plenums off when I did plugs.
I did organ boots last summer |
928: Serial Enabler
I've bought online an led penlight on the end of an 18" flexible extension.
Amazon.com: streamlight stylus 18 inch Home Improvement It works real well to reach into tight areas and backlight stuff to search for leaks.
84,85,86 928 cars |
Petie3rd
if after cleaning off the tensioner you see it leaking,
you can refill it , USE STP oil treatment, use a visene bottle with the tip drilled out , remove both of the fill and outlet plugs. Note it gets filled from the hole closest to the passenger fender. NOTE the other possibility is that sealant wasnt used on one ofthe tensioner bolts this would seal the bolt to the oil return in the block
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats |
hard to pin point even from underneath
looks like spraying ![]()
the belts and pulleys are all dry
Wouldn't it be easier to pinpoint if you cleaned it all up and monitor it?
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior 1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
87 951 (All stock commuter) 87 951 (Saturday night Special) 77 911S (token tail dragger) 83 928S (engine back in from tear down, interior gutted) ....Grasshoppah |
Petie3rd
ahh there is a sealant required for one bolt in the tensioner mount,
its in the WSM its one of the top bolts the one closest to the crank centerline top otr the second one down from top
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats Last edited by Mrmerlin; 05-04-2011 at 07:16 PM.. |
would there be any reason not to locktite all the bolts on the tensioner if accessible?
No doubt you're right Merlin, I'l have to look through the WSM again. That got me because I had a leak in that area too and was thinking about it...Bruce
Not to steal this thread but here's a pic of my leak(s)...
Petie3rd
Loctite PTFE is a non setting pipe sealant its while and will seal the threads no lock them, also good on the WP bolts
928: Serial Enabler
Other than some loctite blue on oil pan bolts, I avoid the stuff that hardens.
The white teflon-containing stuff works for sealing the tensioner bolt and the tensioner pivot arm bolt where it enters the water pump. I've used it on WP bolts, too, per Mr. Merlins suggestion. In general though, the bolt holes should be cleaned of grit, same with bolts, and installed with a little oil. And torqued with an accurate wrench, often an inch lb wrench. The threads in the aluminum block are fragile for one thing, but the heads can shear off the bolts on the next removal especially on smaller diameter hardware it the threads are locked. Its a major PITA to extract a steel bolt from fragile aluminum threaded holes. Often the bolts break under the surface so you can/t weld to it. So loctite isn't needed (torqued, the bolts stay put) and can be detrimental.
84,85,86 928 cars |
tried to scan the parts page with the tensioner
could not get it to upload PART NUMBER 15 ? 15 900 074 135 02 hexagon-head bolt M 8 x 62 M28.21/22 (15) N 010 360 6 hexagon-head bolt M 8 x 60 M28.43/44 can someone decifer the model designations at the end? |
928: Serial Enabler
21/22 are manual/auto 16V USA
43/44 are manual/auto 32V USA The PET is written to cover both variations, as well as other variations. I think it covers 83-84 16V and 85-86 32V. Sometimes a chassis number shows a mid year change. A flag also sends you to the technical bulletins in some cases. Not sure how anybody can work on these cars without the morehouse CD's that have all the keys to all these mysteries. Timing belt time?
84,85,86 928 cars Last edited by Landseer; 05-05-2011 at 07:42 AM.. |
