aftermarket electric cooling fans
Has anyone upgraded to aftermarket electric cooling fans?
Which system did you go with and why? How was the installation? Is the removal of the factory pulley fan always necessary? I am considering on my 1985 928S 32v US, Auto |
I am using one from 928 specialist. It is great. I removed the factory electric fan and mechanical fan. It has a dual fan that comes on in stages of heat. The first one works so good I have never hit the second stage. It draws a bit more juice at start up, but less when running. It was a direct bolt in. Fit perfect. All the fit work has been taken car of. I installed it completely in about an hour, easy on the scale of 928 stuff. I'm pretty sure removal of the pulley fan is a must. You will have to figure out how to run your air pump. I removed mine. The ONLY drawback to this fan was it was expensive. Other than that.. great.
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold) Neon SRT4 track car |
928: Serial Enabler
I'm looking for the Taurus conversion parts for one car.
84,85,86 928 cars |
Architecture & Porsche's
Jegs has a $89 16" reversible universal fan: I've installed on two of my buddy's cars: you'll need a relay, but otherwise...they're adequate, even in Texas
555-52110: search once on their site.
Porsche Club Racing National Scrutineer '89 Andial 951 '82 928R '74 911 RSR 3.6 |
Recovering dismantler
I installed a Zirgo ZFU16S 3000CFM, 10Amp, (basically the same as the Jegs fan) in place of the old bosch fan on my 81 - needs a custom bracket to mount it correctly - if anyone is interested i can shoot some photos.
Neil 2009 Mini Cooper 2004 Mercedes CLK500 2024 Subaru Outback Touring XT 2020 Entegra Coach |
Network Native
I like Motorcraft fans, none I know of are close to them in real cfm. The big air mover is the old Mark8 18" fan, over 4000 cfm and 35 amps, then the various Taurus and Tbird fans. Three good rules to keep in mind;
Efficiency is best with a larger diameter, smaller fans have lower efficiency. CFM takes power, a 10 amp fan of the same size blows about 30% of the cfm of a 35 amp fan. Start up current is about 3x running current, so use the right size wire, fuse, and relay. Make the best crimps you can. *** Putting in an electric fan is a great way to force you to REALLY sort out your electrical system. |
Banned
I'm working on a thread about this subject. I'm going to convert my '85 S2 and its 4.7 liter belt driven fan to dual electric fans.
I bought the S4 plastic frame with some aftermarket straight fans in February. I have a computer control to manage the fans, and a relay [with 30 amp wiring] to run the second fan. I have the Porsche frame, with cheap straight fans. I'm working on the air conditioning on my 928, so I'm not sure I can get it installed this week. I have a shop that has worked on the car before, and they have fabricated a new high pressure hose. I was told today that THEY [Kel-tech in FLL] have worked on 928's before, and that this system is a simple Sanden, a Japanese system common on cars from the 1980's, and similar to VW and Audi's of the 1980's. Well, I took my 928 to the shop today, and he told me that he couldn't fix it. It wont accept gas- He thinks it has a blockage somewhere. AC systems that have used the common leak sealers apparently often times create a blockage that winds up with you Pulled Over. I hope you folks get your republicans worked out! |
I was referring to constant draw, not start up. CFM is determined by speed, number of blades and blade pitch. Not current draw - anyway - I do agree with you on wiring - I added a 6G wire (IIRC) directly from the hot post to relay, back to the fan, then used the original fan wiring to power the relay.
Network Native
The current x voltage = power that spins the fan, which moves the air. CFM = power x efficiency. Speed, number of blades, and blade pitch are more factors related to operating conditions like static pressure and "intended" flow rates and effect the efficiency of a fan. Aftermarket fans tend to have lower efficiency than factory fans, especially modern factory fans, but the differences are small compared to the power differences. |
I used an electric fan kit I found on ebay for my '83. It comes with all the wiring/relay,insrtuctions, has a thermostat which allows you to determine when it comes on, low draw, and worked great in the heat of the south. Item # 160569322632, cost about 220.00. On the '85 you may have to leave the old fan bracket in place as the throttle cables are routed through a bracket which is attatched to it.
I didn't notice that my fan had republicans, they must have been internal, it was an easy install and they weren't mentioned in the directions
Banned
That is a talk for a different area; today, I spent $1014 to get my air conditioning working. I've been driving without it since last Halloween. I normally drive with the windows down and the AC off, even in 90 degree Florida heat. I don't sweat, I'm 6'1" and 148 pounds. I run 6.2 miles per day when I'm home, in the heat, in the afternoon. Heat doesn't bother me! I had the AC totally re-done at the 26 year point because I cannot drive the car in rain. All the windows fog up, so I have to have AC, even if I really don't use it. Also, it is stupid to have a car of this value with an important system such as AC inoperative, not that I'm thinking of selling it or anything. Well, I'm poor tonight. Next paycheck comes two weeks from now; Between now and then I'm going to eat a lot of cheap pasta! N! |
I used a single motor dual fan Audi set up on the '83 that I owned. It used a small belt to drive the second fan. It was powered from the hot post and used a relay powered from the ignition. Turn the key and it was on. It was very inexpensive and cooled the engine quite well.
John Curry (Drift King) 928OC member Grand Prix White 1994 GTS AT (The GTS) Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz) |
I was looking at a system from this company.
v12s - Official Website They were nice enough to send me the installation instructions. They provide a shorter air pump belt in their kit. |
Network Native
Any fan should work "ok" with a good factory radiator under most conditions. No fan is going to fix any real radiator issues. |
928: Serial Enabler
Refilling the viscous fan has worked for me on three cars. Makes electric a needless upgrade. Have decided to abandon Taurus fan project and find a viscous replacement for the car that came to me with the fan deleted.
84,85,86 928 cars |
what does that mean, "Refilling the viscous fan"
I am not familiar with that term |
There is a process in refilling the clutch fan with real thick oil. I used some RC Car Diff Lube and so far no overheating issues. Like Landseer, worked for me as well.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior 1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Your local Toyota dealership will sell the stuff as well.
Michael, So Cal 1985 Porsche 928, Black, 5 Speed 1985 Porsche 928, Weissgold Metallic, 5 Speed 1980 Porsche 928, Black on Black, 5 Speed |
i got a new set of ford mondeo 2.6 fans for about £ 56.00. fits the radiator almost perfectly!!!
Geoff |
