-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=15)
-   -   Power seat problem (http://forums.pelicanparts.com/showthread.php?t=623355)
1968-912-coupe 08-07-2011 01:12 AM
Power seat problem
I have an 87 S4 and I installed a new switch on the passenger seat for the rear height and back tilt adjustment and when I plugged the seat in and tried out the new switch and nothing happened, no movement or sound. The other switch for the front height and forward/back adjustment works. I'm guessing the motor for the rear functions is bad? Any other possibilities?
Mrmerlin 08-07-2011 05:25 AM
there are a few relays under the seat one may be burned up pul each one and smell for burning then check each one for operation
1968-912-coupe 08-07-2011 07:07 AM
I didn't know there are relays under the seat. Where are they, what do they look like?
Mrmerlin 08-07-2011 07:56 AM
remove the seat bolts then flip the seat out onto a blanket then look under the seat for the relay panel they look like relays
1968-912-coupe 08-07-2011 03:00 PM
No relays under the seat.
MPDano 08-07-2011 04:03 PM
I know the S4 seats I bought from DanglerB didn't have anything that looked like relays. Just a connector and the Motors.
It was a couple years back so I didn't think I saw any Relays.
1968-912-coupe 08-07-2011 08:33 PM
They're stock S4 seats.
If it was a bad relay wouldn't everything be dead or are there individual relays for front and rear controls?
I think there's something called a power seat relay module. Can anybody confirm this and describe what it looks like and where it's located?
