First time 928S4 owner
Hey, I'm new here and wanted to introduce myself. I'm Erik and I just bought my first 928s4. I found this car local in my area and go a great deal on it. My first project was replacing the blower motor. It was making a bad rattlings sound and there was no air flowing out of the vents. turns out the motor was bad and there was a some mice taking up residence in my vents. Needless to say they where evicted. Now heat and ac are working just fine. Next step will be to address a coolant leak. I still haven't tracked it down, but I have plans on doing a water pump, timing belt replace so I'm sure I will figure it out while I'm in there. heres some pics of my 928http://forums.pelicanparts.com/uploa...1318816342.jpg
http://forums.pelicanparts.com/uploa...1318816425.jpg http://forums.pelicanparts.com/uploa...1318816473.jpg http://forums.pelicanparts.com/uploa...1318816515.jpg |
Welcome to the Board! Looks like you scored on a well taken cared of 928. Engine and Interior Pics please. What did it cost ya?
Thanks , i'll post some pics of motor, and interior after I take some.
figure out where the leak is coming from and post the info here before you take the waterpump off
Welcome to the forum, and more pictures and spill all details. ;)
Get a good inspection done by someone expert in the 928. Plenty of things you don't want to let slide or miss. |
Nice car for sure, any chance you found it in the Marshfield area?
"Get a good inspection done by someone expert in the 928. Plenty of things you don't want to let slide or miss." - Do what the man says, tons of gremlins await you. I love my 928 but i'm glad I'm doing the work myself or else I'd have a second job by now! Get it on the road before the snow flies!!! |
I did get in Marshfield. Do you know something about this car?
Pis of the hvac vent
I'm pretty sure it not suppose to look like this in there.http://forums.pelicanparts.com/uploa...1318894917.jpg
http://forums.pelicanparts.com/uploa...1318894938.jpg http://forums.pelicanparts.com/uploa...1318894955.jpg http://forums.pelicanparts.com/uploa...1318894971.jpg |
Good luck with and welcome to the group! |
Be careful with rodent nests, the dust is dangerous.
CE is the Central Electrical Panel located at the feet of the Passenger. You'll remove a couple bolts and lift a wooden cover. Houses all your Relays and Fuses.
Kickdown Bypass is basically the activating the switch that is located under the Accel Pedal manually. It will keep your car in a lower gear longer. Obviously for auto Trannys only. I installed one in my "S" which helped me smoke an Audo 2.0 Turbo a few months back. |
Thanks |
Check the flex plate for forward movement ASAP. Do a search on "thrust bearing failure". Don't panic....just something to keep an eye on. This, timing belt service and new fuel lines will take care of the "major" issues that could cost you a ton.
Car looks great. congrats |
Thanks for the great advice guys. I'm getting ready to put it up on stands so I can check the flex plate and go over the fuel system. I'll be using all the great info this forum provides.
Swandog64, if you have not yet joined the 928 Owners Club please check us out at: 928 Owners Club - Porsche 928 Car Club - Advocates of the Porsche 928
We are a non-profit org that helps support 928 events all over the world and support owners of the cars with technical and "roadside assistance" programs! Come join us! BTW, your car looks GORGEOUS! |
FYI...in the future if you need to remove the hood, leave the hinges on the hood and unbolt from the fender so there is no hood adjustment need in replacement.
Good Info
Thanks Dean. So I did checked my flex plate / and crank endplay. I have to say that I relieved to see that my endplay checks out. I didnt take a measurement of how much tension my flex plate was preloaded with ,but when I released the clamp bolt, it moved about a 1/8 of a inch. I just bought a PKlamp and will install it after I locate the proper allen cap bolt for the flex plate clamp. Do you think it would be alright to put this hex head bolt back in the clamp. (see pic.) Has anyone seen a bolt like this in a flex plate clamp before? http://forums.pelicanparts.com/uploa...1320883016.jpg http://forums.pelicanparts.com/uploa...1320883211.jpg http://forums.pelicanparts.com/uploa...1320883230.jpg http://forums.pelicanparts.com/uploa...1320883425.jpg |
more
| All times are GMT -8. The time now is 04:09 PM. |
