fuel pressure
well i finally got my 928 running im working on adjusting the timing. but i ran into a problem. it seems like the engine isnt quite getting enough fuel. i checked the injectors they were good. so im thinking its the fuel pressure but looking through the manuals i cant find how to check the fuel pressure my 78 has the cis fuel system. if anyone knows how to check the fuel pressure and what the pressure should be i could use the help.
Network Native
You need a special set of pressure gauges and adapters, Roger has some at Home - 928's R Us Porsche Parts Store .
How did you check the injectors for proper flow rate? Pretty sure one of the Hawaii guys also has CIS, so you might be able to get some local help. |
CIS Gauges are a MUST to have. Take a pic of your Fuel Distributor, most are non-adjustable but some are. For the most part, all your adjustments will be on the WUR (Warm Up Regulator), which is really a Control Valve.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior 1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
'79 928 Euro 5 Speed
I just got done checking mine on my '79. I posted pics of where you can hook them up on the WUR. I believe the pressures are a little different depending on US or ROW. Mine is essentially around 20 psi cold and around 50 psi warmed up. I bought mine from JC Whitney. I also posted a link of the test kit for reference (on a volvo, but the pic shoes the test kit and other helpful info). Some people have not had success with this tester, however, I have used mine many times. This one has lots of adapters and I did not have to buy any additional fittings. The point is you need to get yourself a tester first.
Using the K-jet Fuel Pressure Test Kit ![]()
'79 Porsche 928, '00 Porsche Boxster, '86 Porsche 944, '04 BMW Z4 '77 Fiat Spider 124,'07 Chevy Suburban LTZ '83 Jeep CJ7, '06 Harley Sportster |
to answer danglerbs question i didnt check the flow rate of the injectors all i did was with the caron i uscrewed the injectors just to see if they had any flow they all did ill get pics of the fuel distributer as soon as i can got shcool for the week so idk when ill have a chance thx for the help
Pint Bottles -
Hey Onestar, Like Danglerb, MPDano and Rupey have indicated - it is almost impossible to troubleshoot a CIS system without the proper gauge setup. There are just too many variables involved if your problem turns out to be a fuel pressure issue.
One rough test (without running your engine) that you can make is to check the spray pattern and fuel delivery of your injectors. Just get 8 pint size clear plastic milk or juice bottles. Clean them out - point an injector into each bottle - jumper your fuel pump relay to send power your fuel pump, turn the key to on - then manually lift your air plate for 10 -15 sec. Part 1) Compare the active spray pattern of each injector - turn your key off - Part 2) Measure the level of the fuel in each bottle for an (approximate) equal amount. Although this test is a bit crude it can help to indicate any injector that may need attention. Naturally, it is recommended that this test be carefully performed by a non-smoking participant….. ![]() Good Luck, Michael
1984 928S - "Miss Purdy" 1987 911SC - "Frau Helga" 1986 930 - "Well Hung" 1975 911 Targa "Blue" |
Network Native
CIS specific gauge set, normal fuel injection gauge sets won't have the right configuration or adapters.
AND Fire Extinguisher. |
Mine did. The strange thing is that I can no longer find my set for sale. I tried last year to look for it, for another user who needed a set, no go.
Network Native
Roger has a good set and good deal, I would look no further.
There ya go!
Hi onestar
I am in honolulu and have a CIS gauge set, some CIS spare parts and a fair amount of experience with the CIS on the 928 (although my '79 is STILL not running perfectly). Happy to help out if I can. I'm not a frequent user here (generally on rennlist, but bdangler sent me over) so if you want to hook up contact me via my yahoo email. k_ruiter@yahoo.com. |
