-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=15)
-   -   Clips for rear window trim (http://forums.pelicanparts.com/showthread.php?t=642173)
Yoni_d 11-28-2011 11:16 AM
Hi Guys
I started to prepare my car for complete repaint and while I removed the rear window, I have noticed that the rear window trim was glued to the window. It seems that it should have some sort of clips that hold that trim in place.
I searched for those clips and this is what I found:
http://forums.pelicanparts.com/uploa...1322507721.jpg
My questions are:
1) Is this what I need?
2) If so, how many clips should I get for the rear window trim?
Thanks for your help!
MPDano 11-28-2011 12:11 PM
I think these are screwed in from the underside. I know I replaced some on mine when I was putting everything back together. That looks like a 928 Intl Screenshot. I would contact Tom, and he can tell you exactly how many you'll need. I would be hesitant on used clips, as these are plastic and become brittle. I would go new on these.
Yoni_d 11-28-2011 12:31 PM
Thanks for your effort!
I received an email from Tom saying that I will need 19 of those...it sounds a lot so I wanted to be sure of that...
vandenham 11-28-2011 12:33 PM
There are 16 of these clips holding the window trim. 4 on each side and 4 on the top and the bottom.
Yoni_d 11-28-2011 01:11 PM
Thanks!
