I wish this wasn't 700+ miles away. Transport looks to be between $600 to $700...too much.
Biggest vehicle I have is a 1998 Olds Bravada. I'm afraid a full U-Haul car trailer and a 928 would be pushing its limits.
George in Indiana 928 Weissach #153 Cayenne S |
One possibility is trust bearing failure, crank shaft dug itself into the block...., that would cause the crank assembly to seize.
How was the car doing before? Did it ever shut down while getting to a stop light or stop sign? How long you have had it for and how many miles you put on it? Also what kind of oil did you used in it, brand and weight? Ali |
Recovering dismantler
I'm going with the TBF as well, its an auto, no known history - have you taken a look at the oil - pull the dipstick, let the oil drip onto a piece of white card, and then examine under a very bright light - do you see shiny specs in it - indicative of tbf or main bearing failure.
Neil 2009 Mini Cooper 2004 Mercedes CLK500 2024 Subaru Outback Touring XT 2020 Entegra Coach |
Petie3rd
Neil if you use the dripping oil test it will work better if you use a black piece of cardboard ,
and look at the oil in the sun the metallic particles show up better with black background
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats |
Good point Stan. Also i found that using a flourescing light source on the end of a boroscope and therefore much closer up can sometimes yield better results.
928: Serial Enabler
I'd probably want to get it into the air and change the oil.
The car looks very good in pictures. I'd be hitting it with the paddles until security dragged me off.
84,85,86 928 cars |
Rockin' NW Arkansas
Had the car 6 weeks. I got the title in the mail the day it broke down. Joy! When I bought it, I took it right to my own mechanic and he did a visual inspection on the belt, changed the oil and gave me a list of things to start on such as leaking PS pump and of course the same side ball joint. Other minor issues. He did a tranny filter change, oil change, topped of fluids and new plugs. He said the belt looked new and that it was good, metel braided, reinforced belt.
Matt 1986 Porsche 928 S - Daily Driver 1984 928 S - SOLD, 1986 944 S - SOLD, 1988 944 S - SOLD |
Petie3rd
Matt please post pictures of the belt
Swapper and Ruiner
Sorry to hear that dude. race-cars.com has a motor for sale.
But I wouldn't waste my money on another one of gigantor motors that don't make any horsepower. I'd do an LS-3 conversion and give it some real beans. H
http://forums.pelicanparts.com/paint-bodywork-discussion-forum/502929-diy-iroc-rsr-conversion.html http://forums.pelicanparts.com/porsche-911-technical-forum/649179-rsr-ls-conversion.html |
What kind of oil did your mechanic put in your engine? what weight was it?
Network Native
TBF I'm thinking is usually hot start issues, but eventually thunk, block etc is toast.
You can never go by "looks good" with these belts. Rubber degrades over time. Unless you had good history on the car when you bought it, it's one of the very first things that are changed out. Same with Water Pump and Fuel Lines.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior 1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
dammmmmm id pay $1000 for that
Be done with this thread and go save it!
Rockin' NW Arkansas
Got a buyer. Guy has a few 928's and I think a member of this board. Picking up on Wednesday
Well great and good luck. Now you can look for another 928 and hopefully find a nice one some day.
1986 928S 32 valve engine All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires. Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster |
best of luck to th new owner
You might let the new owner know that there is an 80k mile S3 engine listed on R-list right now for $900 IIRC.
Mike |
