Intermittent - Headlight Slow to Turn On
Over the past couple months I had noticed the headlight were a little slow in lighting up sometimes. Lights would rotate into position, then it would take 2-3 seconds for them to turn on.
Couple weeks ago pulled out all the relays associated with the headlights, then plugged them back in. Problem went away. After a 200 mile leg of our Xmas trip, noticed a delay in the lights turning on after rotating into the up position that night. Noticed the same thing on the return, and also after starting back up after a quick pit stop halfway back. This last time, the lights popped up but didn't come on. Cycled the headlight switch, then after 3 seconds they came on for a split second then shut off. Cycled the switch again then they came on and stayed on. Of the various headlight relays, which one should I be looking at first? IV Headlight Safety Relay XIII Highlight Relay XIV Headlight Dimmer Relay XVI Headlight Control Relay |
Have you verified that your switch is good? We can pull the one off my Euro if you want to test it. Not that I will be driving my Euro for awhile :(
But then it must be working since it's energizing your headlights to go up. Anyways, let me know if you want to use my Switch. |
Not sure if this will help, but take a look at this terminal and make sure it is clean. http://forums.pelicanparts.com/porsche-928-technical-forum/612433-79-head-lights-not-going-down-fix.html
rupesy. my headlights stoped poping up, i will try ur suggestion i think that will help, thank you
| All times are GMT -8. The time now is 07:46 AM. |
