http://www.torcousa.com/1-pix-tal/pr...atf_banner.jpg |
i wish my car was a non sunroof car, just one more thing i have to fix, and iv just never liked em
i wonder if any one else here has bought this lifthttp://forums.pelicanparts.com/uploa...1328358202.jpg
I'm sure it's fine, but I just wouldn't feel comfortable working under 1.5 tons of Porsche suspended from a one-post lift, or anything with "portable" and "lift" in the same sentence. Needs to be bolted to concrete for me.
I saw a You Tube Video of this. I think it was a UK Vid. I thought it was a nifty idea and I couldn't believe how high it got as well. How much did it run you?
I think a lot of people have gone with the MaxJax deal.
There are a few single post lifts that aren't too crazy, but I have to wonder some on the quality since its not likely a big seller to any but DIY types. |
Most Def want to see your 928 lifted on it's max with your Portable Lift.
Do you have a link for that lift?
I'd be very interested in looking at that more closely.... BTW - the car looks nice. Its gonna be a project - but it'll be fun! |
Pretty sure it's this one:
<iframe width="420" height="315" src="http://www.youtube.com/embed/TlqBkpvOuX4" frameborder="0" allowfullscreen></iframe> |
similar i guess,,,i probably got the copy
MSC-6K Mobile Single Column Lift | North American Auto Equipment |
it came today but i have too much customer work to play today,,,hopefully tomorrow i will get that 928 up there and look at that fluid level,,,should i just change the fluid or add some? power steering came back with a little fluid ,my fingers are crossed,, but even if i had to change a tranny ,,the car may be worth saving i think
I like the fact you can actually walk under that lift. Height-wise the unit would fit fine with my 9' tall garage ceiling and if used elsewhere could lift a car to nice tall height.
Interested to hear if it'll fit under a low car such as a 928. They mention 5" minimum pad height but the base on the right side that forms a ramp looks pretty tall. I might be interested in purchasing one if it is actually made in the USA (including all parts). If it's a Harbor Freight China type product, I wouldn't dare walk under it. The website has America in the name, lots of red, white and blue and a few flags...but I've yet to find exactly where the products are made? |
Hey that car is definitely worth saving. You made out good . its worth more than you paid in parts alone.
That said, you may be on your way to a rebuild. What I would do (If I were you) is jack it up, then drain the Torque converter and pan. Check the fluid for shavings and / or burned smell or materials. If it passes the sniff test and you dont have shavings you can use a pump and refil with ~ 7 quarts of ATF (Dex) . let it idle on the lift and top it off (this is if you do not have obvious leaks etc.) My trans had loose pan bolts also so make sure you check them, and your trans lines for leaks. If that doesnt work you will have to yank the trans and rebuild but its a Mercedes Trans :D |
yes made in China what isnt? but its not harbor freight cheap quality |
| All times are GMT -8. The time now is 04:04 PM. |
