Common Transmission leak
I changed the fluid and filter on my transmission a couple months ago. It was leaking pretty good at the time. It's still leaking.
Are there any common leak points/seals etc.. on the 84 AT? The leak seems to be near he resevoir somewhere.. rear of the pan, looks below the seal somewhere.. I just haven't been able to nail it down yet. Thanks -Dan
1979 Porsche 911 Black on Black widebody 3.2 - SOLD 2015 Jeep Wrangler Sport Unlimited - White 1984 Porsche 928s Black on Black - SOLD |
A common leak is the front pump seal. It will normally start dripping through the torque Converter area. Your seems like the opposite end. There are multiple Cover seals on your tranny. I normally look on the parts diagram and will show what in that area. Use Pelicans parts diagrams as they are good.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior 1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Petie3rd
from the info provided it sounds like the leak is one of 3 places,
the tank, loose or worn gasket or the cap isnt tight or the gasket is missing the pan gasket, if the pan isnt flat where the gasdket sits then this will lead to overtightening of the pan bolts thus cracking the gasket. or the bowden cable O ring, remove the bowden from the trans and replace the O ring on the bowden cable housing
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats |
I didn't know the Bowden has an o-ring there, good to know.
Petie3rd
the pan gasket will split or crack if the pan is overtightened
dont use any RTV to seal it. If your pan is leaking then remove the pan and true it up prior to installing it, if you cant true it to flat, then replace the pan
How do you true it?
