Coolant gauge question (is it working?)
I am terrible when it comes to electrical troubleshooting.
My coolant gauge is not registering. I have taken the plug off at the engine water bridge and ground the blue wire and the gauge will register hot. I then ground the brown and the alarm light will light on the gauge. I tested the resistance between each terminal blades of the sensor to ground. Nothing registers on the meter. When I put the plug back on the sensor the gauge will not work. I have also replaced the sensor. I hope I explained my problem well enough. Thanks. Mike P
1988 Porsche 928 S4 (rescue) |
Try cleaning the grounds under the steering column.
1980 AUTO Synergy Green Metallic / Black & Grey ( my son's) 1989 Auto Slate Grey Metallic / Cashmere & Black (mine) 1982 5-speed White / Black sport seats ( brothers ) |
I will clean the grounds when I get home tonight.
Where is the needle on the gauge suppose to be pegged at normal running temperature? Thanks. Mike
Dean, I cleaned the grounds behind the dash. Not an easy job. I am tall. Still not working.
What else can I do? Thanks for the help.
