80 928
Euro Camshafts
I have recently aquired an '83 4.7 engine. So, my question is: 1) will euro cams work in it, and will it still be a non-interference engine? 2) Do any of you fine shark owners have a pair of euro cams, they would part with for a reasonable figure?
Thanks, Kerry
They will work. Not sure about the interference part. Its the combination of higher comp pistons, bigger valves, bigger intake, and bigger cams that made the Euro's more hp. You may see very little gain with just cams.. and they are VERY expensive if you can find them.
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold) Neon SRT4 track car |
Medipedicman over on rennlist has euro parts and a complete euro parts car. He is in the Chattanooga Tn area and a first rate guy to deal with. I know he was selling heads just acouple days ago
1980 AUTO Synergy Green Metallic / Black & Grey ( my son's) 1989 Auto Slate Grey Metallic / Cashmere & Black (mine) 1982 5-speed White / Black sport seats ( brothers ) Last edited by Dean_Fuller; 08-02-2012 at 09:31 AM.. |
80 928
Thanks, Kerry |
pm coming
1980 AUTO Synergy Green Metallic / Black & Grey ( my son's) 1989 Auto Slate Grey Metallic / Cashmere & Black (mine) 1982 5-speed White / Black sport seats ( brothers ) |
928 Junkie
Here are pics of the two sets of Euro heads, with camshafts still in. I am still trying to determine what year these are from.
Struggling with the PET .?.? Euro Heads - Rennlist Discussion Forums Thanks Dean
Brian Phillips 1979 928 , 5-speed, cork interior 1982 Euro S 5-speed project 1985 928S, auto(sold)1978 Euro 5-speed (found another home)1983 928 s 5 sp short shifter black/black (sold)1982 928 auto (sold) |
928 Junkie
I was just looking on the parts side and it appears that each individual item is sold seperately.
Camshafts Heads Exhaust valves Lifters Piston ring sets Valve guides Valve springs. The two sets that I have available are complete sets. The only things not included are the bolts and of course a new gasket set. PM any offers.
80 928
I have no idea what you are looking to get (on a tight budget). If the price is right, I guess I could buy the heads for my domestic 4.7, (however, I would be happy with just the cams.) Are these the euro S 4.7 cams (M12)? Thanks, Kerry
928 Junkie
Hey Kerry
That is the big question right now. I have the parts numbers listed next to the pics, However I have been unable yo determine MY. The cam shafts alone are $1200 each side on this site and used ones fetch $750 each side on others. I need to be in the $1000 ballpark for the complete setup.
80 928
928 Junkie
That would be for ONE set which would include both cams, headers and all of the above listed items. The only thing it would not include are the mounting bolts and gasket set.
I have two complete sets. You could have first choice based on photographs and part numbers. I would be happy to take further pictures of the one you are interested in from any angle. You and I both would want full disclosure and both parties to be happy when the deal is complete.
80 928
I'm getting my engine delivered this week, so after I do an evaluation on it, I'll get back to you -Kerry
928 Junkie
Hey Kerry, I have had a person much more knowledgeable than I am kind of take me under his wing on the parts listed above. It has been a pleasure and I have learned a lot. The best we can determine, at this time, the ONE complete set of cam tower housing and heads is from a 1979 Euro which was the 4.5 L engine. There will be no distinguishable difference in performance between the US version and the Euro version for this MY.
While you are welcome to still consider these items, and I believe they would be fully functional in your setup, they may not achieve your goal of higher power. I am going to remove one set of valves and put a proper measurement on it. I have just purchased a micro-meter but cannot get an accurate reading with the valves in the closed/unsprung position. I will post results as I get them. I would love to see pics of your new engine. ![]() I ran across this picture when doing research and it was very helpful for me.
80 928
Will do Brian...I'm planning a mild euro/us hybrid ie: 4.7us with the higher lift euro cams, lower us CR, reusing my tubular headers/3" exhaust system (no Cat), K/N air filter, 28 deg euro timing setting. My goal is about 260hp/ 285lbft tq (at crank) with a little more rev capacity. -Kerry
16v Head Comparison ( US vs Euro S vs 951 ) - Rennlist Discussion Forums .
1984 928's w/ 5 speed Smoked Quartz Metalic 1982 928's Turbo w/ 5 Speed Platinum Metalic 1978 Euro Widebody w/ 5 speed Guards Red |
928 Junkie
That is awesome Sean thanks. That is WAY simpler than what I had in mind. (c clamps,cardboard, and spring compression)
My tool looks identical to the one pictured and should get reading quickly. Thanks for the kindness and the knowledge.
928 Junkie
![]() Well that settles it. The cam towers and heads are 1979 US. Another friend helped me to identify an extra set of valves that I have as Euro S. Still in factory wrap. I enjoyed reading your write up about compression and I will study it further. Thanks to everyone for your help. Now lets find Kerry some Euro S cams.
Just curious. Are 81 Euro 4.5 Cams the same as the 4.5 US Cams?
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior 1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Network Native
Non S I think so, but part numbers would tell all.
80 928
I could be mistaken, but did any 4.5L engines get the high lift cams(.472/.432), or high flow heads?
