1982 928S
RE: wheel hight
Hi guys, i was looking at front of my car and sides, i noticed my driver side is an inch lower from passenger side. could this be engine mounts or springs or may be problem with front end. any ideas guys. Thanks Ed.
Architecture & Porsche's
sagging springs due to blown shocks: most cars will sag to the driver's side due to constant weight of the driver being present.
You can check to see if your car has threaded (adjustable) spring perches & merely raise the driver's side up to level it out...or lower the passenger's side. If yours are not adjustable, then a newer set or aftermarket springs will do the trick.
Porsche Club Racing National Scrutineer '89 Andial 951 '82 928R '74 911 RSR 3.6 |
Post a pic of how the motor looks in relation to the cross bar. That would tell if its one motor mount.
1980 AUTO Synergy Green Metallic / Black & Grey ( my son's) 1989 Auto Slate Grey Metallic / Cashmere & Black (mine) 1982 5-speed White / Black sport seats ( brothers ) |
