-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=15)
-   -   key question (http://forums.pelicanparts.com/showthread.php?t=700369)
plyhammer 08-30-2012 09:08 AM
key question
On my 79 my key just pulled the ignition cylinder out? Is there a set screw or something that keeps the key cylinder in the chamber
MPDano 08-30-2012 02:45 PM
Should be obvious when you remove the surrounding plastic. I believe it's located right on the top. I know I ended up using a small screw in mine since it was missing, probably a common misplaced or vibrated out part.
