low charging
can low charging 12.6 make the auxiliary air regulator to fail or give wrong result when testing foreksampel different sensors.the car runs bad
Old 10-04-2012, 01:18 PM
Network Native
Danglerb's Avatar
12.6v is battery, not charging, charging is more like 13.5 to 14.5v.
Which Aux air regulator, what model and year, some run from the engine brain, others are just a solenoid, but I would not suspect 12.6v to be an issue with either.
By runs bad, does it want to vote for Obama or something less serious?
Old 10-04-2012, 01:29 PM
1981 928s eru norway.sorry about my english.it will be better
Old 10-04-2012, 02:10 PM
Network Native
Danglerb's Avatar
81 Euro S is CIS injection, runs bad is almost always some issue with WUR, fuel distributor, fuel pressures, faulty previous mechanic, intake vacuum leaks, or injectors needing cleaning.
Euro used CIS from 78 to 83, US 78 and 79 only, but many here on Pelican will be able to help with the details.
Tell us more about how it is running bad. Hot start, cold start, idle, full throttle, etc. What all does it do wrong?
For almost all troubleshooting you will need a set of fuel pressure gauges made for testing CIS systems.
Old 10-04-2012, 06:52 PM
Pete R's Avatar
One thing with CIS that should be checked first is vacume leaks before replacing components. My car went from running like bad lawn mower to a racecar 1 with plug of a small leaky line.
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold)
Neon SRT4 track car
Old 10-04-2012, 07:04 PM
when i drove it for the first time,only one thing to say.funny funny.but after 2 days he dident suprise me anny more.slow ,black smoke mixed whith blue smoke on heavy akselerasjon.when cold he is better
Old 10-06-2012, 02:15 PM
