LED Upgrade
Installed Jaeger's LED upgrade for the dash lights. Chose blue and love it. Much brighter. Now I can see the gauges at night. I also ordered the dimmer switch for the LEDs. I found that(at least for the blue color) did not need it. Waste of money. A pic.
http://forums.pelicanparts.com/uploa...1356198302.jpg |
Looks great! I did mine in red LED's. Now you will want to use blue LED's in your console and shifter.....:)
how tough to install
Well you have to remove the instrument cluster first. I have gotten so good at that, that it was the easy part. Really, the only trouble I had was that the LED's come with a plug you insert in the existing bulb holder and on two of the holders they didn't make good contact. Thank goodness I tested the lights before putting the instrument cluster back in(I actually read the instructions he,he). I had to bend the metal in the bulb holders to make good contact. It took several tries. I used my VOM for continuity checks until I finally got good contact for all bulb holders. But I am so happy with the results. I now look for trips to take at night.
Looks great. I am thinking about doing it. What all comes in the kit?
Mike P |
it's easy to install leds in knee consoles shelfs, in dome lights, even put small leds in inside door handle. Seems too many passengers have a hard time finding the handle at night.
The dimmer switches can be found at many sellers of leds. found mine for $27. |
What do you guys think of the
Seem to be a lot of them here. |
| All times are GMT -8. The time now is 10:00 AM. |
